Old 12-20-2001, 11:38 PM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default Where can I purchase good inecxpensive autometer guages?
Looking to get 3 guages for my new modified housing. Where can I get nice loking guages at?
Jasno999 is offline   Reply With Quote
Old 12-21-2001, 12:30 AM   #2
tEkkGOD
Member#: 10110
tEkkGOD is offline   Reply With Quote
Old 12-21-2001, 12:52 AM   #3
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Default gauges
Yep-
www.summitracing.com for autometer
Omori has a special right now on gauges for a bit more but they're making special colored needles and everything for the new WRX to match OEM gauges! I want those but need a few more bucks. Check it out....
www.omorimeter.com
Look under specials.
JR (WRX34)
WRX34 is offline   Reply With Quote
Old 12-21-2001, 07:39 AM   #4
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
What exactly do I need to purchase. I want to get a boost guage that is mechanical. I want an oil pressure guage that is electrical and a voltmeter.
DO I need to purchase tubing or wire do get this all done. Let me know what extra thngs I have to purchase with my guages. And what guages do you guys like best? Is Autometer my best bet?
Old 12-21-2001, 07:50 AM   #5
spd wgn
Member#: 8571
2002 wrx
imho....
I tried autometer but the illumination doesn't match the stock dash very well (dim). I am waiting for replacement VDO Vision Series from Summit. I think VDO makes a good product, good pricing, US made (Virginia)
on the vision series the numerals are lit from behind just like the dash, and you can change the colors with little red or green boots they supply
spd wgn
spd wgn is offline   Reply With Quote
Old 12-21-2001, 10:25 AM   #6
trboCIVIC&WRX
Member#: 6426
jasno-
if you buy the autometer stuff, they usually come with the tubing and wiring necessary for installation. You just might need to come up with your own wire for the illumination bulbs...
trboCIVIC&WRX is offline   Reply With Quote
Old 12-21-2001, 11:07 AM   #7
wrxracer
Member#: 5275
2002 impreza WRX
WR BLUE
Talking autometer gauges
some people like it some don't...try www.nopi.com i use them all the time, you can even go to there on-line shop and see a picture of most items, just go to the universal and choose the gauges it will ask you what you want to see and look at...its simple...hope this helps
wrxracer is offline   Reply With Quote
Old 12-21-2001, 01:44 PM   #8
loafing1
Member#: 7133
2002 WRX Wagon Slvr
1991 Toyota 4Runner
i have autometer ultralights. right now they're half-installed - in the car and illumination wiring is hooked up. i think they look great and light up fine. they do have all the necessary wiring for that part (illumination)... well, i guess you do need to extend it to splice in w/your dash lights. they come with a red and green cap for the bulbs. the green lights up looking real nice on the silver faces; i think it matches the green dash lights fine. i did notice the boost gauge lights up slightly dimmer then the other two. just like i've read the factory subaru one to do! interesting... must really have something to do with the boost gauge internals being different. it's not that much difference though, at least on my autometers. not enough to make me care.
loafing1 is offline   Reply With Quote
Old 12-21-2001, 05:18 PM   #9
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
spd wgn imho....
spd wgn
WHERE DID YOU PurCHASE THE VDO GUAGES?
Old 12-21-2001, 05:25 PM   #10
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Also what kind of oil pressure guage should I get 0-100PSI or 0-150PsI or 0-200 PSI.
I am not sure how large the pressures arre for the WRX.
Old 12-21-2001, 07:31 PM   #11
spd wgn
Member#: 8571
2002 wrx
jasno999
I got the gauges from Summit...not in their printed catalog, but off their online site...just put "VDO" into their search engine
(which is a generally crappy search engine for some reason)
and it wil show the VDO options
spd wgn
Old 12-21-2001, 11:02 PM   #12
Gerry
Member#: 1829
Dude.Save your money and buy gauges that work...You'll thank me later...Gerry
Gerry is offline   Reply With Quote
Old 12-22-2001, 12:36 AM   #13
hman
Member#: 3747
2002 Impreza WRX
Platinum Silver Metallic
I got my at Summit too. Good services.
hman is offline   Reply With Quote
Old 12-22-2001, 05:05 PM   #14
tdman77
Member#: 9832
2004 STI
Summit is great! I would go with the VDO instead of the autometer. The price is pretty close but the quality is much better. They more closely match the stock lighting also.
tdman77 is offline   Reply With Quote
Old 12-23-2001, 01:22 PM   #15
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
What is the pressure range that I should get for my oil pressure guage for my 2002 WRX? 0-100, 0-150 or 0-200 PSI
Old 12-24-2001, 12:47 AM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I can't imagine a production vehicle would see above 100psi, so I'd go with the 0-100# gauge.
You could ask the service guys at the dealership what kind of pressure a healthy engine sees at high RPMs when it's still cold - they probably have some guidelines in their tech manuals.
Pat Olsen
'97 Legacy 2.5GT sedan
Where can you purchase a drain plug for oil temp sensor? ninjaboy76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-28-2003 03:12 AM
how much where can I purchase cheap, functional OBD-II scanner> dingo dave Normally Aspirated Powertrain 4 02-27-2003 12:55 PM
what's a good, inexpensive boost gauge? where to get it? rex n effect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-28-2002 02:27 PM
Where can I purchase Cross drilled/slotted or just slotted rotors? 2002 WRX Jasno999 Brakes, Steering & Suspension 3 04-01-2002 11:35 PM
Where can I get some inexpensive 22B hood vents??? IMPRZME Interior & Exterior Modification 4 04-07-2001 12:31 AM
