Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-30-2007, 09:49 AM   #1
bobko
Member#: 64646
1995 Legacy wagon
Green
Default Coolant Temperature Sensor (ECT) location
Where is the Electronic Coolant Temperature (ECT) sensor located? I have a 1995 Legacy with an EJ22 engine.
I appreciate the help!
--Bob
bobko is offline   Reply With Quote
Old 05-30-2007, 04:28 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It's located at the back passenger side of the coolant cross-over pipe, which runs underneath the intake manifold. It's pretty tough to see/access with the intake manifold in place, but if you look down below the throttle body and towards the passenger side a bit you should see it. All the ones I've seen have a brown plastic connector.
Pat Olsen
Old 05-30-2007, 05:26 PM   #3
bobko
Member#: 64646
1995 Legacy wagon
Green
Thanks Pat! I looked there but I will look again.
--Bob
Old 05-31-2007, 03:08 AM   #4
achix
Member#: 58609
Pat Olsen
I think the connector is of triangle shape.
Also the sensor (once you unscrew it and take it out) is about 5cm long.
You can examine its output with ECUexplorer to see if it gives reasonable values.
achix is offline   Reply With Quote
Old 05-31-2007, 12:29 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
Old 05-31-2007, 03:48 PM   #6
bobko
Member#: 64646
1995 Legacy wagon
Green
Originally Posted by Legacy777 View Post
That's super.... thanks! I went out to my car last night and looked again, and found it just as your picture shows. I'll have to get a bunch of hoses out of the way to get at it but it should be easy to do once I clear the way. I assume the single-wire sensor next to the ECT sensor is the sender for the temperature gauge. I'll be sure to clean up that connection.
--Bob
Old 06-01-2007, 12:36 PM   #7
Legacy777
Member#: 4800
Yeah, you're correct, the single wire sensor is for the temp gauge on the dash.
I think the newer models don't have the single wire sensor though....
Old 04-03-2009, 12:59 AM   #8
tomthedancinghobo
Member#: 207473
Default Location on Loyale?
My loyale is coding a temp sensor fault. Haynes tells me to check it... but they don't say where it is! Where is the coolant temp sensor on the 1.8L (Nat. Aspirated MT) loyale engine?
Thanks!
tomthedancinghobo is offline   Reply With Quote
Old 04-03-2009, 01:47 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I can't say for certain, but I wouldn't be at all surprised if it's located in the coolant cross-over manifold just like on the larger EJs.
Pat
Coolant temperature sensor location Turn Right Racing Normally Aspirated Powertrain 3 12-17-2007 04:54 PM
coolant temperature sensor Pizzaman Service & Maintenance 2 10-13-2005 08:01 PM
Engine Coolant Temperature Sensor Resistance? LetItSnow Normally Aspirated Powertrain 3 11-20-2004 11:40 AM
Any tips on taking off coolant temp sensor? tough location! Max Umbarger Service & Maintenance 0 12-01-2003 02:38 PM
Location of coolant temperature switch? biggreen96 Legacy Forum 2 11-27-2002 04:31 PM
