Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-19-2007, 02:10 PM   #1
06njsti
Member#: 150986
06 #001 LSB STi
Default AC dead
im not sure if the ac went in my 06 sti. it still blows cool air but nowhere near the temp it used to blow it at. should i try and add freon to to ac or take it to a shop to have them check it out. what problems could it be?
06njsti is offline   Reply With Quote
Old 06-19-2007, 02:14 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Go to a shop, unless you have the right tools and experience AC service isn't a DIY. It may be low on refrigerant, or there may be another problem. Either way it should be looked at by a professional. If it is low it's probably due to a leak which needs to be fixed.
Actually, if you have 36K or less just go to a dealer, it's under warranty.
Old 06-19-2007, 02:26 PM   #3
06njsti
Member#: 150986
06 #001 LSB STi
ok thanks i have 29k on it and im gonna go to a dealer.
Old 06-19-2007, 10:24 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Also, make sure that the recirculation button is on....it will take the inside air and keep cooling it, rather than taking the hot outside air and attempting to cool it.
It WILL make a difference, especially if it is humid out
RexyGirl is online now   Reply With Quote
Old 06-19-2007, 10:34 PM   #5
06greysubie
Member#: 130700
06 COBB tuned vf39
dark metallic gray SON!
i have a quick question. I punctured the thin a/c line by the firewall. tried to use jb weld but didn't work once i charged the system. could i just get an aluminum welder to plug that tiny hole up or will i have replace the line??
thanx
-ben-
06greysubie is offline   Reply With Quote
Old 06-21-2007, 08:32 PM   #6
RexyGirl
Member#: 63616
with mods :)
thanx
-ben-
Seeing that is a pressure line, nothing will hold it, at least not for long. You would be better off replacing the line. it's not that expensive.
AC is shooting mist and frost out vents TSReynolds Service & Maintenance 16 06-16-2010 03:12 PM
My AC compressor is sick or dead KootenayWRX Service & Maintenance 4 01-19-2009 01:13 PM
AC dead again :( fastnoypi South West Impreza Club Forum -- SWIC 5 06-10-2008 10:54 AM
AC compressor dead? help needed. elsanto Service & Maintenance 5 05-10-2006 03:36 PM
AC is dead? BongMan Normally Aspirated Powertrain 5 06-20-2001 08:45 PM
