Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-01-2007, 10:33 AM   #1
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Default increasing turbo fuel efficiency
I've heard it suggested in several places that if you upgrade the induction and exaughst components of your turbo you will more than likely see better fuel efficiency (that is as long as you don't jump on the gas all the time - the primary reason FOR getting bigger components)
I was wondering if anyone who's done any turbo performance upgrades have noticed any increases in fuel efficiency? BajaSTI05? Cliffhanger?
moonzie is offline   Reply With Quote
Old 06-01-2007, 06:21 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
Mine has been pretty much the same as far as highway miles. 24MPG. City driving has decreased, but thats because I like to use the throttle a lot.
Hawk296 is offline   Reply With Quote
Old 06-02-2007, 01:45 AM   #3
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
I use to got 29-30 best and 27-28 average in my wrx with catless uppipe, magnaflow muffler and short ram intake. Was a bit lighter and only a 2.0, but these all added power and mileage.
bobjr94 is offline   Reply With Quote
Old 06-10-2007, 03:50 AM   #4
Dave G
Member#: 4738
2006 Baja Turbo
I switched from dino oil to Castorl Syntec 5w-50. I've been getting approx 2mpg better hwy mileage ever since. My driving style has not changed, and the roads I drive on are the same.
The 2mpg is an increase of approx 10% in gas mileage.
Dave G is offline   Reply With Quote
Old 06-12-2007, 09:12 AM   #5
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
I've done a few things, most of them with no effect. I think the ECU really negates the changes, especially to fuel/air tweaks.
I've had a local muffler shop install a nice stainless dynaflow and cut out the resonator. I've taken off and put back on the intake silencer elbow in the fender. I've added a KN. I've switched to synth gear fluid. I've made a scoop that forces air into the intake a bit better than the stock set up (removed the plastic dam on the hood for a quick improvement).
I'm maybe getting 1 to 1.5 better mpg. I really suspect if I could lean it out a bit, it would get about 5% better yet.
dfritz is offline   Reply With Quote
Old 06-12-2007, 12:36 PM   #6
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I also tried removing that little dam up front on the air intake, but it had no effect on my fuel efficiency after 2 fillups.
I'm probably going to take my Baja into a local muffler shop and have them do some custom 3" exaughst on it. But that wont be til Fall.
New Tire Rack Test Confirms Low Rolling Resistance Tires Equal Increased Fuel Efficie AVANTI R5 Non-Subaru News & Rumors 13 09-24-2009 12:05 PM
Question on NA vs Turbo fuel efficiency G.Subramaniam Normally Aspirated Powertrain 4 08-07-2006 06:00 PM
Spiralmax, turbinator? Increase fuel efficiency? Mr.Tickles Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-08-2005 09:14 AM
Increasing Hood Scoop Efficiency for AX makofoto Motorsports 42 07-07-2004 05:47 PM
Turbo fuel efficiency question driver8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-19-2001 08:38 AM
