Old 12-21-2001, 05:45 PM   #1
Boom
Member#: 1101
04 STi
like theres a choice BLUE
Default Squeaking noies when clutch pedal is fully released help!!
Well the noise comes when I am idling at a stop. If I touch the clutch pedal the noise goes away. If I play with the pedal I can make the noise get a little louder, and then if I push a but more, I can make it go away. I am thinking that its the throw out bearing, but I am not an expert. If anyone can give me any help I would really appreciate it.
FYI I have a 99 Impreza RS, 53,000 miles, Manual Tranny, just changed the tranny oil, but the noise happned before I changed it. Original stock clutch, no slipping at all. Still feels very good, smooth engagement, and smooth clutch feel.
Steve
99 White RS
Boom is offline   Reply With Quote
Old 12-21-2001, 11:33 PM   #2
SubeTek
Member#: 1714
1999 RS-T COUPE
Definitely throwout bearing noise. Although sometimes the grease on the pivot ball for the throwout fork dries out and will cause the same noise, as the bearing and pressure plate are always touching somewhat. Hope this helps.
Bret Carter
Subaru Senior Master Tech
SubeTek is offline   Reply With Quote
Old 12-24-2001, 04:10 PM   #3
Boom
Member#: 1101
04 STi
Well thats ok, do you think its going to be covered by the 60,000 drivetrain warrenty? Or is it a wear part that wears out and is not covered by warrenty. Thanx for any help, and the help you have given already.
Old 12-24-2001, 11:05 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
Good chance this will be covered by warranty-as it is a bearing problem, but i can't give you 100% assurance without looking at the warranty guide. You should try calling your local dealer and asking first, but i'll try to remember and post back on wednesday when i return to work.
Have a great Christmas!
Bret
Old 12-26-2001, 12:01 AM   #5
DannyGT
Member#: 6281
2002 Impreza WRX
Graphite Pearl - SOLD :(
Funny i get a VERY similar sound with my rex. When i press my clutch down all the way makes no noise, but once i release it, u hear a kind of gear meshing noise (best way i can explain it) its VERY VERY low, but i noticed it b4 i got my exhaust, when i would be in idle in my garage and press and let go i would get this gggggrrmmmmmmm sound but very low....i cant even hear it now with my exhaust.....
DannyGT is offline   Reply With Quote
Humming Noise when clutch pedal is not depressed airspeed Transmission (AT/MT) & Driveline 7 08-11-2008 01:40 PM
Weird bubbling noise when clutch pedal is pressed in? tobylazur Transmission (AT/MT) & Driveline 1 07-28-2007 12:58 AM
Metallic Clicking sound when clutch pedal depressed Craig W Transmission (AT/MT) & Driveline 4 07-31-2005 10:14 PM
squeaking noise from clutch pedal? sjw Newbies & FAQs 5 05-28-2004 09:10 AM
help, my clutch pedal is mushy! SUBACHI Transmission (AT/MT) & Driveline 1 07-08-2003 01:15 PM
