Old 06-02-2007, 06:39 PM   #1
deebee8
Member#: 85437
2002 Wrx
Land of the dead
Default PCV Valve REPLACED Idle Problem GONE!!
Hey all, just thought id share my experience with you guys.
Car has the usual on it,
VF30
FMIC
Catless turbo back
EM
Protune. yada yada
Anyways, I started having a MINOR idle issue, The car would shoulder every couple of seconds, not a big shutter, but my vaccum would lose a couple psi everytime it happened.
I started to replace all vacuum lines hoping for there to be a slight crack in one.
No Luck.
I was walking through napa autoparts today to buy some hoseclamps and stumbled across the PCV section, 3.49 cents later, i have a new PCV Valve ready to install.
Im bored, wifes gone for the weekend, so i said what the hay, lets work on the car.
Took off Turbo Charge Pipe, Took off stock BPV Recirculation fitting, pulled off the hose to pcv.
Now the cool part is, you can use a DEEP 3/4 Socket to get it off, yeah i know im supposed to use metric, but i didnt have one, but it worked great. Came off, went back in with no troubles.
Fired up the car, let it warm up, and BAM, idle issue gone. Car idles STRONG!!!
I know its not a fix for everyones problem, but my stock PCV was pretty gummed up, it might help some people on here with higher miles =)
For what its worth, ENJOY!!!
Eric Van Scoy
deebee8 is offline   Reply With Quote
Old 06-02-2007, 08:47 PM   #2
rubinm
Member#: 63483
2005 STi HTA68'd+e85
hey thats awesome to hear! ive got the same issue currently.. any tips or writeups on replacing the pcv valve??
thx
Milo
rubinm is offline   Reply With Quote
Old 06-03-2007, 10:11 AM   #3
pictureboy
Member#: 85132
2016 WRX
Ditto here for similar idling issue. I will try this next weekend!
pictureboy is offline   Reply With Quote
Old 06-03-2007, 12:08 PM   #4
Feign
Member#: 68604
06 STi
thx
Milo
1) Remove intercooler.
2) Replace PCV.
3) Replace intercooler.
Feign is offline   Reply With Quote
Old 06-03-2007, 10:11 PM   #5
deebee8
Member#: 85437
2002 Wrx
Land of the dead
yeah, in all honesty, its as easy as the above post. absolutly nothing to be scared about, an oil change is more labor intensive than pulling the pcv
Old 06-03-2007, 10:55 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
A 3/4" socket is 19.05 mm, so not surprised it worked if the pcv is 19mm - another good one to remember is 7/8" which is 22.2mm (I had a 6-pt box wrench which I used for my rear transverse bushing - worked like a charm)
Confused on PCV valve replacement goldice42 Service & Maintenance 15 11-27-2010 04:33 PM
PCV valve replacement db97 Service & Maintenance 37 11-07-2010 07:31 PM
PCV valve replacement interval HudsoN456 Service & Maintenance 10 05-23-2002 03:22 PM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 09:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
