#1 |
Member#: 12620
Vehicle:2004 STi Aspen White |
Sorry if this is redundant, but, my search came up empty.
What do I need to wire a flat-four connector for trailer lights? Is a "Modulite" required to maintain system voltage and not cause light-drag? Or do I only need a $20 converter kit? Thanks, Curtis
#2 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
Are you wiring one from scratch or going to use the Subaru hitch/wiring kit?
Glenn |
#3 |
Member#: 12620
Glenn,
I would like to use a generic converter. The subaru part is $90 retail, $55 @ cost. A generic converter is $20. I reviewed everything that you had posted on the topic, as well as others comments. What did you use to wire yours? Thanks, Curtis |
#4 |
Member#: 456
NWIC
I used the Subaru converter that came with the Subaru hitch kit. Of course, there's no real advantage in using it unless you have a TS wagon as the WRXs and RS don't have the connector.
You might find my cheat sheet is helpful in figuring out the wires to connect to anyway. Here it is with the Subaru harness colors removed, leaving the general description and wire to tap from. 1. +12v -- connect to Blue/Red wire on trunk light (requires long wire) 2. Right Turn -- connect to LightGreen/Blue in rear RH light assy 3. Stop -- connect to White/Blue wire in rear RH light assy 4. Left Turn -- connect to Blue/Green wire in harness near rear RH light assy 5. Tail Lights -- connect to White/Red wire in rear RH light assy 6. Ground -- connect to ground Black wire in rear RH light assy As usual, if your car catches fire, don't blame me. ![]() Glenn |
#5 |
Member#: 8943
TXIC
Vehicle:2006 MINI + Corvette Both Blue |
Glenn - Thanks for the information!
GoodFinder ![]() |
| Thread Tools | |
| Display Modes | |
| FS: *NEW* Trailer Hitch Wiring Harness | Iroc8210 | Exterior/Styling | 1 | 07-19-2007 11:50 AM |
| WRX Trailer Hitch Wiring cheat sheet | ANZAC_1915 | Service & Maintenance | 3 | 03-10-2006 07:29 AM |
| WRX trailer hitch wiring | tshrey | Electrical & Lighting | 2 | 07-16-2004 02:02 PM |
| 02 WRX Wagon trailer hitch wiring. Help! | Dusty Wagon | Electrical & Lighting | 7 | 12-14-2003 12:36 AM |
| Trailer Hitch Wiring | DavidPorter | Factory 2.0L Turbo Powertrain | 0 | 05-31-2003 12:34 PM |
