Old 06-04-2007, 02:02 PM   #1
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Default Perrin atmospheric bov leaking
Has anyone used this bov? If so, chime in here.
Today I decided to pressure check my boost piping.
I found out that there is a somewhat bad leak at the bov where the piston seats into the body.
Any suggestions to fix this? I can tighten the bov with it's adjustability, but I tried screwing the cap on a couple turns and it made no difference.
akira02rex is offline   Reply With Quote
Old 06-04-2007, 03:18 PM   #2
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
yeah i had one too. mine leaked as well, i got rid of it.
Rexwagon03 is offline   Reply With Quote
Old 06-04-2007, 03:33 PM   #3
12SECWAGON
Member#: 149258
04 WRX Wagon
Java Black
You're probably tired of hearing this, but go back to a bypass/recirc valve.
12SECWAGON is offline   Reply With Quote
Old 06-04-2007, 07:59 PM   #4
AlboWRX
Member#: 37719
2003 WRX
Well if you think thats where the leak is, I would pull it out and make a fitting for it so you can test it with some pressure to see if it really is the bov!
AlboWRX is offline   Reply With Quote
Old 06-05-2007, 09:16 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Yeah..because the stocker can hold 20psi+ right?
I'm running a 20G with high boost.
Old 06-05-2007, 11:15 AM   #6
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Ok, another question...
If I tighten down the cap more, will that make the piston seat tighter?
I read Perrin's installation instructions and they said the cap does NOT make the piston hold more boost...how is that possible??
I am looking at how it's designed and it seems as though when I'm in boost the volume above the piston is pressurized w/ boost that would equalize out the pressure under the piston (inside the tmic).
There is a rubber O-ring that is placed on the body where the cap screws on and it is cracked. If this O-ring is cracked then that will definitely give me a boost leak and thus, the pressure is no longer equalized above the piston and below the piston anymore.
Old 06-05-2007, 06:57 PM   #7
AlboWRX
Member#: 37719
2003 WRX
Change out that o-ring if you can. Just take it to a big hardware store you know and tell them to get you a similar o-ring. Also make sure to lube that o-ring up. That`s probably the reason it cracked.
If you tighten the cap more, it should hold hold more boost. That`s why they have it there to adjust in the first place!
Try to take out the valve and hook up the small nipple to a compressor with a gauge and put about 30psi in it. Put soap bubbles on it to see if there`s any tiny leaks. It wouldn`t hurt the bov in any way. If the compressor is not available you can maybe get one of those ball inflators.
Or you can skip all the above and just swap out your valve with someone else`s in your area.
Old 02-19-2013, 11:24 AM   #8
Quiksmith
Member#: 266230
2006 WRX STI
To be clear tightening this BOV does not allow it hold more boost. It actually adjusts when it blows off. The tighter it is the more you would have to let off throttle for it too blow off. If really loose the valve would open instantly by even slightly letting off the throttle. The benefit of tighter is holding more boosts between shifts. Drivability could suffer if you go too tight or loose, perrin says the way it comes from factory is the most ideal. These are supposed to hold 200ish psi from factory, if you are leaking check install and the o-ring mentioned above.
Quiksmith is offline   Reply With Quote
FS MA: Perrin Atmospheric BOV xrocket21 NESIC Private Classifieds 0 02-23-2009 01:25 PM
FS MA: Perrin Atmospheric BOV, black 7k miles xrocket21 NESIC Private Classifieds 1 11-25-2008 07:20 AM
FS MA: Perrin Atmospheric BOV, Black, 6k miles xrocket21 Engine/Power/Exhaust 2 11-25-2008 07:20 AM
FS: Perrin atmosphere BOV highrevracer951 Engine/Power/Exhaust 10 08-19-2008 02:00 AM
FS: Perrin Atmosphere BOV highrevracer951 SCIC Private Classifieds 69 08-09-2008 07:01 PM
