Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 12-22-2001, 01:10 PM   #1
SONofSAM
Member#: 8407
Thumbs up What is the different 2.5L and 2.5RS
Can you guys tell me what is the different between these two engine's! 2.5L and 2.5RS?
cause i'm getting the 2.5L twin cam engine from a 98 legacy 20K
and do the swap onto my 1.8 L model impreza 5 speed AWD...
what else do i need the guy sell me the engine is include the Harness and ecu plus altnator and compressor for A/C and enigne mount ( you think the engine mount for these engine will fit better then what i have on my 1.8? or i need to upgrade it!
all for these comes with paper for 450 flat. you think is a good deal!
What else do i need? you think i'm all set!
and what is the shipping will cost from New york!
SONofSAM is offline   Reply With Quote
Old 12-22-2001, 01:57 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Make sure you get the intake tract upto the MAF. Dont want to have to buy one. Ummmm you might need the crossmember. Dont know if there 1.8l one will support the ej25 well?
Midwayman is offline   Reply With Quote
Old 12-23-2001, 08:39 PM   #3
rbehny
Member#: 1908
well the twin cam 2.5 legacy sounds like the same as a 98 rs which came with a twin cam 2.5 liter. That's the only year they had twin cams. Check to see if it's a phase 1 or phase 2 block cuz i've heard that the phase 2's are better... reason why they are better, i have no clue
later,
Robert
rbehny is offline   Reply With Quote
Old 12-24-2001, 12:28 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Ummmm, the engine in the 2.5RS is a 2.5L engine. The "L" stands for "liters", it's not a model designation.
As pointed out already, the '98 Legacy 2.5GT's 2.5L engine is the same as the '98 Impreza 2.5RS' 2.5L engine. The MAF sensor might be different, but that doesn't really matter. Definitely get everything on the intake side, all the way to the filter box, as that stuff is pretty expensive. Also make sure you get at least the exhaust header, and probably the cat pipe, too. I'm sure the header is different than on the 1.8L, and there's a good chance the cat pipe is also. Actually, it would probably be good to get the entire exhaust, as I imagine the 1.8L's exhaust is pretty small and will choke off the 2.5L a bit.
If he's giving you the 2.5L's engine mounts, then use them. You could also look into getting STi engine mounts, which would set you back about $100-110 I think ($165 if you get the tranny mount too).
Pat Olsen
'97 Legacy 2.5GT sedan
PS - You slept through English class in high school, didn't you, SoS?
Patrick Olsen is online now   Reply With Quote
what is the difference with revisions and versions with the UTEC ? billy boi Engine Management & Tuning 3 01-27-2005 01:06 PM
what is the difference between saden and wagon? motr Vancouver Impreza Club Forum -- VIC 8 10-29-2002 07:04 PM
What is the difference between forged and cast wheels? disc108 Brakes, Steering & Suspension 12 10-10-2001 02:47 AM
What is the difference between 18mm and 20mm WRXwannbe Brakes, Steering & Suspension 15 10-27-2000 02:59 PM
what is the difference between V4 and V5 wings Cata Vancouver Impreza Club Forum -- VIC 1 09-28-2000 08:47 PM
