06-05-2007, 11:25 AM | #1 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
hydra and obd2
Now of course I know that the Hydra will not pass an obd2 emissions test, but can you do any diagnostics through the obd2 port? In particular I wanted to look at the cooling fan relays and the ABS system.
06-05-2007, 12:12 PM | #2 |
Member#: 58251
Vehicle:2004 Sti GT35R 530whp @ 27psi |
Cooling fans are controlled by the hydra, so that is a definite no in that regard.
Whether or not you can communicate to the other OBDII computers in the car, I would probably say no, but I am not positive as I have not tried it. It is not really a big deal to swap back to the stock ECU if you need to hook up an OBDII scanner to diagnose something, it probably takes 20 minutes. |
06-05-2007, 01:11 PM | #3 |
Member#: 30367
South East
Where are the cooling fans controlled in the Hydra? I couldn't find it.
06-05-2007, 03:14 PM | #4 |
Member#: 58251
For an STi, Settings->Outputs->PWM 13 controls the fans.
For a WRX it is probably a different output. |
06-05-2007, 03:49 PM | #5 |
Member#: 30367
South East
06-05-2007, 08:41 PM | #6 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
The OBD 2 will not read as it's part of the OEM ecu so you just won't be able to connect. The WRX also uses output 13 for fan control but the secondary fan is also controlled via the AC control.
Thanks, Phil www.elementtuning.com |
Can the hydra pass OBD2 emissions? | lukeskywrx | Other Engine Management | 19 | 04-07-2006 03:19 PM |
Urgent: Cel Resistor Fix and OBD2 | ScoobySteve123 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 04-05-2006 08:01 PM |
cobb cable and obd2 software | scoobdude | Engine Management & Tuning | 5 | 10-29-2005 02:26 PM |
NY Inspection and OBD2 | sfjohnson | Tri-State Area Forum | 11 | 07-27-2005 10:40 AM |
When using a Palm and obd2 software... | mrtrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-14-2002 01:20 AM |
