Alaskan Impreza Club
Old 06-05-2007, 08:36 PM   #1
Jaylyons1
Member#: 113884
2013 BRZ
Default Flashing CEL
Ok so I researched this and every one I found seemed to be when the engine was running.
I jumped in the 05 sti today just to start it up as I do every once in a while since its garaged, i noticed before I started it that the CEL is flashing. It doesnt stop as long as the key is engaged. Also the fan keeps turning on and off. Of course this has to happen the day someone says they will buy my car... Anyway, anyone know what this could be? Im assuming its probably a cheap fix. Engine is brand new so cant be that.
Also, how much would it cost to fix engine thats misfiring?
Jaylyons1 is offline   Reply With Quote
Old 06-05-2007, 08:43 PM   #2
KuroiSTi
Member#: 93547
01 2.5 RS
Mine did that one day and It turned out I just hadn't screwed on the gas cap all the way
It will go away after 3 driving cycles...whatever the hell that consists of
KuroiSTi is offline   Reply With Quote
Old 06-05-2007, 09:45 PM   #3
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
My CEL's go away on just a random errands around town.... any time you turn the car on and off three times, if the problem does not exist anymore, it will go away.. But for a blinking CEL, that doesnt sound good. Jay, call up conti and ask for jerry or dale.
MikeyMike is offline   Reply With Quote
Old 06-05-2007, 10:20 PM   #4
ponamy
Member#: 115511
2005 wrx /w babyseat
2011 Forester 2.5x
sounds like what happens when you have the green test connectors under the dash hooked up for an AP reflash.
reflashed lately and forget to unhook those connectors?
ponamy is offline   Reply With Quote
Old 06-05-2007, 11:08 PM   #5
Jaylyons1
Member#: 113884
2013 BRZ
Havent reflashed but I did swap radios. Ill check that out, was gonna try and swap the 04 into the 05 anyway ^_^
Old 06-06-2007, 12:12 AM   #6
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
yep, it's in d-check mode. what ponamy said...
00Maddog is offline   Reply With Quote
Old 06-06-2007, 04:16 AM   #7
ponamy
Member#: 115511
2011 Forester 2.5x
i hope thats all it is, that would suck to just come out one day and have my car flashing cel's and fans blowin at me lol.
let me know so i can be relieved for you
Old 06-06-2007, 05:07 AM   #8
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
did you install the radio or someone else? I don't see how they got plugged in installing a radio........
t4nk is offline   Reply With Quote
Old 06-06-2007, 05:32 AM   #9
ponamy
Member#: 115511
2011 Forester 2.5x
possibly if someone was installing the radio other than the owner they could have said, "hey theres a couple connectors that arent hooked up, maybe i should hook em up for him"
i know i know, it sounds far fetched hehe.
you'll get it figured out jay
Old 06-06-2007, 05:35 AM   #10
t4nk
Member#: 129905
2005 WRB WRX
yeah but installing a radio, they shouldn't be anywhere near the wires...
unless you installed an amp in the trunk, then the power wire would need to come through the firewall.. very possible... mine are plugged in all the time lol i have them on a toggle switch. works pretty damn good for tuning..
Old 06-11-2007, 05:34 AM   #11
ponamy
Member#: 115511
2011 Forester 2.5x
did you figure it out yet? lemme know jay.
Old 06-13-2007, 09:39 PM   #12
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
problem fixed, some genius reconnected the d-mode connectors i guess when jay had a stereo put it or when they were swapped
tribalwrx is offline   Reply With Quote
Old 06-13-2007, 10:21 PM   #13
ponamy
Member#: 115511
2011 Forester 2.5x
lol, sweet. at least you got it taken care of. glad im not completely full of crap either haha.
Flashing CEL-Solid CEL-no codes? Turbovan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-15-2009 10:32 AM
Flashing cel with cel disabled. L80Killa87 UTEC 15 09-28-2006 07:39 PM
2 CELs, GAS Smell, Flashing CEL, HELP! Zerolapse Service & Maintenance 1 09-15-2006 11:50 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 10:43 PM
Flashing CEL vs. Solid CEL Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2003 12:01 AM
