Old 12-22-2001, 06:47 PM   #1
eastbaysubaru
Member#: 4110
04 FXT
Unhappy HELP! Electrical Problems...
My car died today. I was just finished going on a
short errand and the stereo shut off, then the wipers
were moving REALLY slow, then the car started idling
wierd and died. I think it's either the alternator or
the battery. The battery has been having problems,
and the battery light lit up last night as I was
coming home. At this point I think it's the battery,
but how do I check? If that's not the case, how do I
check the alternator to see if it's functioning
properly? I've got to jump it now because the car
isn't starting on it's own power, so I'm wondering if
I'll get an accurate reading from a voltmeter. What
else can I do? HELP! TIA!
-Brian
eastbaysubaru is offline   Reply With Quote
Old 12-22-2001, 09:16 PM   #2
SilverSubi
Member#: 9856
2011 STI
PBP
What does the voltmeter say the voltage of the battery is while the car is off? It should be at least 12 volts if it's good.
Take the same reading while the car is running to see if the alternator is providing current.
Good luck.
SilverSubi is offline   Reply With Quote
Old 12-23-2001, 01:11 AM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I've had four Subaru's, and I've had the same problem once with each and every one of them. It's your alternator- you may want to replace the battery anyway, as the stock battery is rather small (cold cranking amps and reserve capacity-wise that is). I just did this with my 2000 RS a few months back.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Need help, electrical problem. VMI06WRX04 Electrical & Lighting 3 05-17-2010 05:02 AM
Need Help! Electrical problem eclone Subaru Conversions 4 01-02-2005 01:43 PM
Urgent help! Electrical problem? V8ETR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-27-2002 11:46 PM
('93-'01) Help!! Legacy Electrical Problems mhj Impreza Forum 4 07-26-2001 08:32 PM
('93-'01) Please help - Electrical problems Boeleni Impreza Forum 2 04-08-2001 09:53 AM
