Old 06-28-2009, 10:35 PM   #1
skep18
Member#: 214971
2014 WRX
Default Stock Up Pipe Issues
So, yes, I'm a n00b here. I searched and there are just so many posts that pull up that aren't relevant.
My question is, I have heard the stock up pipe can be a problem. Something about if something in the cat comes loose, say buh-bye to your turbo... Anyone got any more information on this claim?
Thanks.
skep18 is offline   Reply With Quote
Old 06-28-2009, 10:54 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Yes. Your stock cat in the stock uppipe can dislodge and/or come apart, and it will destroy your turbo. If there's only one thing you ever do to your car, it should be replacing that uppipe with an aftermarket uppipe. Not only will you gain some throttle response, spool, and power, but you will save your turbo from possible death. If you do add an aftermarket uppipe, you need to unplug the EGT sensor that's in the stock uppipe and put a 2.2 kohm resistor in its place so as not to throw a CEL.
Pour yourself some hot cocoa (or Jager) and read this
http://forums.nasioc.com/forums/showthread.php?t=443943\
PS- 947 people will say that all you need to do is to gut your factory uppipe, and the results are the same as an aftermarket uppipe. That's not true. While your main issue is safety, an aftermarket uppipe will make more power and enhance throttle response better than an STi uppipe or a gutted factory uppipe. That is a fact, not an opinion.
Audiosavvy is offline   Reply With Quote
Old 06-28-2009, 11:06 PM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
That.
Audio, for people like me in CT, would we pass emissions with a catless uppipe?
skep, if you need a catless uppipe, I got one for $40 shipped
Jubert69 is offline   Reply With Quote
Old 06-28-2009, 11:29 PM   #4
skep18
Member#: 214971
2014 WRX
Thanks for the info. My car has low mileage, but I'll definitely start planning on that one.
Old 06-29-2009, 03:02 PM   #5
Chris Cuevas
Member#: 75547
2016 STi-ICE Silver
SRP P&P'd VF22 + NOS= RIP
Originally Posted by Jubert69 View Post
That.
Technically speaking, as long as you have one cat... You will pass the sniffer test. Just not the visual inspection if that applies to your state. I am in CA, and they do both. I had bolt the OEM DP back on to pass emissions among other OEM parts...
As far as the issue at hand, I agree about the stock up pipe being an issue.
I replaced the OEM UP with a Perrin after about 2 months of owning my 02.
Chris Cuevas is offline   Reply With Quote
Old 06-29-2009, 03:48 PM   #6
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
1) Remove stock uppipe
2) Gut stock Uppipe
3)Re-install gutted Uppipe w/o egt sensor and plug bung
4)Use 2.2 Ohm resistor in stock plug in location
5) Be on your way for about $5
Brock31 is offline   Reply With Quote
gutted stock up-pipe VS sti up-pipe mhorn0817 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-01-2009 10:42 AM
FS: 04 WRX Stock down pipe, stock up pipe, and stock springs LitosWhtWRX SCIC Private Classifieds 6 01-30-2008 03:02 PM
FS So-Cal: GT Spec up-pipe, stock up-pipe mister hashimoto Engine/Power/Exhaust 0 11-21-2007 12:27 AM
FS: TXS Up-pipe and Stock Up-pipe Calsoldier Private 'For Sale' Classifieds 0 06-26-2005 05:40 PM
WTB: gutted stock up-pipe uppipe up pipe jaybert Private 'Wanted' Classifieds 4 06-28-2004 10:44 AM
