Old 06-07-2007, 11:12 AM   #1
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Default P0327 Code thrown- confirming understanding
Basically this code seems to mean my wiring is ****ed up.
Mine throws when the car has been sitting and it has been damp out, so I am thinking I have an exposed wire.
Sideshowbob is online now   Reply With Quote
Old 06-07-2007, 11:15 AM   #2
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
knock sensor low input - check your knock sensor and the wiring and make sure everything is intact. or replace the sensor.
anthonyrb98 is offline   Reply With Quote
Old 06-07-2007, 11:18 AM   #3
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
cool, but it usually goes away on it's own. I will check it thou.
Old 06-07-2007, 10:55 PM   #4
crazymikie
Member#: 56321
2006 Honda El Camino
Green
low input means that there is additional resistance in the wire or it's grounding out somewhere. i would start by checking the wires around the connectors for the knock sensor to see if they've become exposed.
You could also try measuring the resistance of the knock sensor itself. I don't know what it should be offhand.
crazymikie is offline   Reply With Quote
Old 11-10-2008, 09:44 AM   #5
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
popped again!
happens after the car sits out on really raining hard and windy.
I'll check the wiring someday, my car isn't knocking
Old 11-10-2008, 10:46 AM   #6
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
remove the knock sensor and clean the base where it mounts, on the block and sensor.
crampfan is offline   Reply With Quote
Old 11-10-2008, 12:10 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Bob.....fill in your damned profile so we know what the hell vehicle we are talking about
and if this is a pre01 NA engine....throw the damned sensor away and put a new on in and be done with it already....those sensors are known to have issues
Old 11-10-2008, 02:15 PM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
If you do this make sure you torque it down to the correct specs. The knock sensor is basically a small piezoelectric microphone and is very sensitive to overtightening or rattling from being too loose.
Personally, I think it's a broken wire or loose harness plug.
Haelan is offline   Reply With Quote
Old 11-10-2008, 08:31 PM   #9
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
^- +1 for what that guy said. if it happens mainly when its raining then i would think its a wiring issue.
romanlynch is offline   Reply With Quote
Old 11-10-2008, 09:17 PM   #10
mwichtendahl
Member#: 182944
2011 WRX Limited
You are extremely correct, sir. I would say to check out the knock sensor, and replace it if necessary. Also I would probably do it sooner than later since you don't seem to motivated to do it.
Edit: The reason you need to fix it soon is because if your computer thinks that it is knocking, its going to retard the timing until it stops knocking. If the sensor isn't functioning properly, then you might have an issue on your hands.
mwichtendahl is offline   Reply With Quote
Old 11-12-2008, 11:28 PM   #11
GlennB
Member#: 99926
2003 Bugeye
awdtuning.com
i threw this same code today as well. besides just the sensor malfunctioning are there any other causes to this? i haven't been driving my car lately and all of a sudden it threw this code so i'm just curious.
GlennB is offline   Reply With Quote
Old 11-12-2008, 11:42 PM   #12
Haelan
Member#: 151045
2013 Subaru STI
CBP
Not really. The device is very simple. The complex knock signal analysis is done in the ECU. The knock sensor itself is basically a small piece of metal that picks up sound waves and converts it to electrical energy. If the ECU doesn't even see noise there is a loose connection somewhere or the knock sensor itself took a crap.
Old 11-13-2008, 01:39 AM   #13
GlennB
Member#: 99926
2003 Bugeye
awdtuning.com
k. thats what i figured. i installed a reverse scoop and theeeen it rained. guessing the water ****ed it up.
Old 03-09-2009, 02:15 AM   #14
hanzo918
Member#: 82148
1992 Daihatsu
Charade
/sigh
I have this code.
I've replaced the knock sensor
Replaced the entire engine harness
and it still throws the code.
hanzo918 is offline   Reply With Quote
Old 03-09-2009, 02:32 AM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by hanzo918 View Post
/sigh
I have this code.
well it aint a ****ing 92 dihatsu so what the **** car IS it??
Old 03-09-2009, 10:27 PM   #16
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Oops.. didn't expect anyone to care. =)
It's a 06 STi
Old 03-10-2009, 12:12 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
seems like a bad wire or sensor or other electrical issue
Old 03-10-2009, 12:28 AM   #18
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Yeah... granted I've swapped out the sensor and the whole engine main harness...
I'll double check the torque to be 17lbs and the resistance...
Old 03-23-2009, 04:35 PM   #19
shinsain
Member#: 51745
LIKE A
BOSS
Hey guys, hate to necromance here but I saw this thread was already made...
I'm getting this code in my 04 WRX and I'd love to check this, but I have no idea offhand where the knock sensor is located physically in the car/on the engine. Could someone kindly point me to a diagram, picture, or explain it? Thanks...
shinsain is offline   Reply With Quote
Old 03-23-2009, 04:41 PM   #20
Haelan
Member#: 151045
2013 Subaru STI
CBP
Facing the front of the car--look behind the alternator on the engine block. It will be circular in nature.
Old 03-29-2009, 06:09 AM   #21
hanzo918
Member#: 82148
1992 Daihatsu
Charade
So I swapped out my sub-harness with a good one. Still no go.
And checked the service manual's wiring diagram (06 STi), it's not matching up to the engine harness.. It looks like the previous owner was messing with the ECU, and ended up using the wrong wiring harness to the ECU.
Does anybody know the Subaru part number for the big tube of wiring that goes from the engine bay to inside the fender to the ECU? I think I'm just going to order a new harness....
Old 05-25-2009, 12:05 PM   #22
pvbyl
Member#: 19661
2006 WRX STi
hanzo, any update? MY06 STi just started this as well...
pvbyl is offline   Reply With Quote
Old 05-25-2009, 01:22 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
And checked the service manual's wiring diagram (06 STi), it's not matching up to the engine harness.. It looks like the previous owner was messing with the ECU, and ended up using the wrong wiring harness to the ECU.Does anybody know the Subaru part number for the big tube of wiring that goes from the engine bay to inside the fender to the ECU? I think I'm just going to order a new harness....
****in stupid bloody kiddie bastards
Old 05-25-2009, 11:58 PM   #24
jasonspeed
Member#: 187971
03 Grocery Getter
subyshop.com
Agreed, I've seen too many cars that were trashed by people who simply made uninformed decisions and messed up an otherwise good car.
jasonspeed is offline   Reply With Quote
CEL troubles codes thrown, need help plz Stylz916 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-21-2010 08:47 AM
CEL with 4 Codes Thrown G Langa Newbies & FAQs 0 07-14-2008 11:00 AM
several ecu codes thrown spoolinred Service & Maintenance 6 04-12-2008 10:21 PM
ST codes thrown rustyzipper AccessPort 0 08-24-2007 12:25 PM
Double CEL blink, no code thrown superg Engine Management & Tuning 5 03-02-2006 12:44 PM
