Old 06-07-2007, 12:53 PM   #1
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
Default One more Frankenstein 2.5/2.2 question.
Hey guys, started mocking things up a bit, just had a question about this small bracket. Did you guys cut it off, I dont see any other way around it due to the cam gear of the 2.2 heads hitting it. I believe its only purpose is to hold the timing cover on.
Let me know, side note everything still ugly in the picture is coming off and getting replaced/cleaned so it will look good when under the hood. Even if it only lasts a few days being clean.
Thanks in advance.
Air
Not All There is offline   Reply With Quote
Old 06-07-2007, 03:02 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Disassemble the engine further. From what I recall, that bracket isn't part of the block. It should unbolt from it...
Old 06-07-2007, 04:12 PM   #3
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
Ok thats what I was hoping.
Old 06-07-2007, 05:04 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
Thinking about it more, I think it's part of the timing belt tensioner bracket. You should be able to just bolt your stock one to that same location. And if you don't have the stock engine out and need one, let me know. I've got a bunch of them and will sell you one for cheap...
Old 06-07-2007, 06:07 PM   #5
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
ok i might just do that, im looking to get the motor built up downstairs while I continue driving the subaru the way it is now daily. Shoot me a pm and let me know.
2.0 to 2.5 hybrid build question mvcsk8r Built Motor Discussion 3 07-27-2014 08:30 PM
Frankenstein 2.2/2.5 Engine Build questions. Not All There Normally Aspirated Powertrain 36 06-01-2007 02:28 PM
97 2.2 -> modern 2.5 NA swap questions bl_easy Subaru Conversions 2 12-20-2006 11:48 AM
1.8/2.2/2.5 brake compatibility questions- any experts? Aspen Brakes, Steering & Suspension 9 08-11-2004 02:26 AM
97 impreza l wagon 2.2- 2.5 swap clutch questions MC Racing Transmission (AT/MT) & Driveline 1 04-24-2002 01:47 PM
