Old 06-07-2007, 05:10 PM   #1
elementsk8trbam
Member#: 117181
2006 Wrx Limited
WHITE
Default Will Disconnecting My Postive Battery Terminal Wipe Out My Stage 2 Map?
I just wanted to know if Disconnecting My Postive Battery Terminal to clean it will that reset the ecu and force me to reflash the car when I attach it agian? I have the accessprt with the stage 2 93 map.
elementsk8trbam is offline   Reply With Quote
Old 06-07-2007, 05:15 PM   #2
washyu
Member#: 16424
2004 STI
it will revert to whatever basemap you uploaded.
washyu is offline   Reply With Quote
Old 06-07-2007, 06:03 PM   #3
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
what about when using ecuflash? it is a reflash so it should be burned on the chip and not just a real-time map.
bluemax189 is offline   Reply With Quote
Old 06-07-2007, 06:12 PM   #4
shemoves
Member#: 80663
2005 STi
It does clear the ECU, but only part of it. It will clear the realtime map, but not the basemap. You do not need to go through the long flash process again.
If that map you had on there is not the basemap, you will need to use your Accessport to put it back on (assuming you saved it onto the port). It's very simple. With the ignition 'On' (motor can be running or not, you can even techinically even be driving...(insert not safe/car accident/get off you accessport and drive comment here)), plug the AP into the car. IIRC, you go to 'change realtime map' and select the one you want. Wait ~ 30 secs while it does it's thang and vioala. Unplug the AP and enjoy.
shemoves is offline   Reply With Quote
Will an STI stage 2 map work for me? roloc31 Built Motor Discussion 3 11-20-2008 06:06 PM
I always have deposits on my positive battery terminal -=C=- Off-Topic 18 09-09-2008 04:29 PM
Question: Do I need to reload stage 2 map if my battery died? ASpel SCIC Private Classifieds 2 02-11-2008 01:35 AM
Got my PDX Stage 2 map sleestak6326 AccessPort 28 05-19-2006 12:47 PM
My unichip with stage 2 map finally arrived! cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-10-2002 01:14 AM
