Alaskan Impreza Club
Old 06-10-2007, 03:28 AM   #1
prometheum
Member#: 92003
04 TDI Passat
Default any autocross rules gurus out here?
http://forums.nasioc.com/forums/showthread.php?t=174189
according to this
Beyond Street Modified
# Anti-Lift Kit (relocates suspension mounting points).
# Braces other than strut tower braces: triangulated braces (V-braces), lower arm braces.
1: what does relocates suspension mounting points mean?
2: "Braces other than strut tower braces"...does that include fender braces?
edit: what about the perrin subframe braces?
prometheum is offline   Reply With Quote
Old 06-10-2007, 06:32 AM   #2
soldmyboxster
Member#: 65520
'11 M3 Coupe
1. The factory suspension bolts into holes in the unibody of the car. If you use different holes than what the factory uses, consider it relocated. Also, if you use a suspension component which alters the geometry of the suspension (i.e. a longer toe link, longer lower control arms for more camber, etc.) you probably put yourself in the same category. Adjustable top hats (another way to gain camber) would qualify as a relocation.
This ad for an anti-lift kit specifically states it relocates a mounting point: http://cgi.ebay.com/ebaymotors/GT-Sp...QQcmdZViewItem
2. Looks like the Perrin subframe braces bolt into a ton of different places! That would definitely qualify as a brace "other than a strut tower brace". The fender brace is also considered "other than a strut tower brace", because it doesn't connect to the strut towers at all.
soldmyboxster is offline   Reply With Quote
Old 06-10-2007, 05:24 PM   #3
soldmyboxster
Member#: 65520
'11 M3 Coupe
As an aside to #2 above, there's a way around the frame bracing rules: get a rollcage. As long as it doesn't have more than six mounting points to the body of the car, it's considered a piece of safety equipment, rather than a stiffness mod.
any wiring harness gurus out there? svxpert Tri-State Area Forum 0 04-01-2008 09:31 PM
Any suspension installation gurus out there.... SirWilliam Mid Atlantic Impreza Club -- MAIC 20 05-14-2007 11:39 AM
Any classic cartoon gurus out there? bruticus Off-Topic 7 01-31-2005 12:20 AM
PhiLLY HeaDs: Any good cruising spots out here? Not for racing of course VTECmyARSE Tri-State Area Forum 3 02-27-2004 05:31 PM
Any Linux configuration gurus out there? veloLexus Bay Area Impreza Club Forum -- BAIC 7 10-24-2002 10:47 PM
Message Board Statistics All times are GMT -4. The time now is 04:38 PM.
