Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-10-2007, 01:08 PM   #1
yoshi86
Member#: 131478
1986 -AE86-Grey
2007-2.5i-WhitePearl
Default Question of using wider tires
First of all, sorry for my poor english
I recently put the 04' STi wheels on my 07' 2.5i.
-STi wheels tire size is 225-45-17
-2.5i wheels tire size is 205-55-16
When you drive, if you let go of the steeling wheel, the wheel will snap to one side or the other a little bit, if the surface of the road is not perfectly flat, or bumpy.
After I put the STi wheels on, I find that the steeling wheel is going crazy to left or right if the road is not flat or bumpy.
Is it normal for a wider wheels or do I need to do something
yoshi86 is offline   Reply With Quote
Old 06-10-2007, 02:30 PM   #2
oem
Member#: 330
Default Road's fault
Yoshi, it is the roads fault. being that you are in Vancouver, i am guessing by "road not flat" you are talking about two ruts or grooves formed by years of chained and studded snow tires being driven on the road. Basically your wider tire cannot fit into the ruts and every time an edge of the tire moves into the rut you feel the steering wheel snap to the left or right. try sticking to one side of the lane and see if there is a difference.
edit: i feel stupid, just looked at Vancouver's annual snow fall...like 5" at most. i figured it was like denver...jerks wear studded snow tires all winter long, no matter if it is snowing or not.
Last edited by oem; 06-10-2007 at 04:28 PM. Reason: looked at Vancouver's snow fall
oem is offline   Reply With Quote
Old 06-10-2007, 04:10 PM   #3
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
Originally Posted by oem View Post
...being that you are in Vancouver, i am guessing by "road not flat" you are talking about two ruts or grooves formed by years of chained and studded snow tires being driven on the road.
Studs or chains in Vancouver is tres funny!!
It is the correct answer though... the pulling is your tires "tramlining" along the uneven surface.
shawmacs is offline   Reply With Quote
Old 06-10-2007, 04:17 PM   #4
yoshi86
Member#: 131478
1986 -AE86-Grey
So is it:
wider = more pulling?
Old 08-02-2007, 10:28 AM   #5
AdamB
Member#: 104203
2006 Impreza 2.5I
Steel Gray Metallic
I'm thinking of putting the same wheels (from and '04 STi) onto my 2.5i. Have you had any rubbing problems? I called tire rack and they say 17"x7.5" 53mm offset will rub the suspension on a 2.5i.
AdamB is offline   Reply With Quote
Old 08-02-2007, 10:59 AM   #6
sixtoo
Member#: 67603
2007 WRX Wagon
Urban Gray Metallic
If you have a stock suspension setup, you wont have any rubbing issues with the 2.5i and some STi wheels (even under full load). If you decide to lower the car, then you'll have problems. You'll see that the rear wheels still look a little tucked in with 7 inch wide wheels.
17 by 8 is a different story.
sixtoo is offline   Reply With Quote
WTB: a set of used snow tires stephan Private 'Wanted' Classifieds 2 09-01-2004 09:11 AM
WTB: set of used rims/tires benfranklinwrex Private 'Wanted' Classifieds 2 07-27-2004 11:17 PM
WTB: set of used rims/tires benfranklinwrex South East Region Forum 3 07-27-2004 10:57 PM
harms of using diffrent tires.. 555 Brakes, Steering & Suspension 3 12-20-2002 09:05 PM
22b suspension mods to use wider tires Jessie James Brakes, Steering & Suspension 4 03-29-2001 06:45 PM
