Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 12-24-2001, 01:24 AM   #1
Member#: 12879
1992 Legacy L Wagon
5spd, AWD, White
Default what do you do if you have only one key, and you lose it?
Does the dealer have a master key that works on all cars of the same model?
Does the dealer come to your house to unlock it?
How does one get a new key?
Does one have to change the ignition & locks?
I thought I lost mine today, only to find it (miraculously) on the staircase of my building.
GusS is offline   Reply With Quote
Old 12-24-2001, 04:18 AM   #2
Member#: 8678
Silverish 2.5GT
being that you found the key, i'd safe the smartest thing to do is to go make some more copies ASAP. i believe that if you had actually lost your only key, subaru would be able to replace (probably at a cost) based on your VIN number. not too sure about this "master" key theory though.
GTkrockett is offline   Reply With Quote
Old 12-24-2001, 02:15 PM   #3
The Real Oaf
Member#: 6608
1996 Legacy Outback
If the lost-now-found key is a factory key, there should be a number on it. Give that number to your local dealer & they can get you a key...might even be able to notch one out while you wait.
If you don't have the factory key, the lock cylinders have the needed number on them.
The Real Oaf is offline   Reply With Quote
How do you know if it's a real one... Tattoo! Interior & Exterior Modification 3 12-24-2009 08:43 PM
If you are a fan at a sporting event, and you make it on camera.... Fach Off-Topic 33 11-02-2007 09:03 PM
WTH! What to do if the toilet is being used and you have to go.... at work... Sephro Off-Topic 18 09-21-2005 11:59 AM
Do you care if your spouse makes more $$$ than you? Strider Off-Topic 32 03-24-2005 03:50 PM
How Do I Tell If I Have Keyless and Security? Al_Smokemcrack Electrical & Lighting 7 12-26-2004 05:39 PM
