Old 12-24-2001, 01:47 AM   #1
kAn9ArOo
Member#: 2294
Question 30000 mile service
hey i was wondering if any has their receipt from the 30k service.
what does the dealership actually service? i have a 2000 R.S.
thanks.
kAn9ArOo is offline   Reply With Quote
Old 12-24-2001, 04:17 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
If you've got your owner's manual, this is what they're supposed to do:
Inspect Drive belt(s) [Except camshaft]
Inspect Camshaft drive belt
Replace Engine oil
Replace Engine oil filter
Perform Replace engine coolant and inspect cooling system, hoses and connections
Recommended Performance Replace fuel filter and inspect fuel system, hoses and connections
Replace Air cleaner element
Replace Spark plugs
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Inspect Automatic transmission fluid
Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Clutch operation
Inspect Steering and suspension
Lots of dealers like to add stuff as recommended items that aren't on the list, then charge to the max.
CosmoTheCat is offline   Reply With Quote
Old 12-26-2001, 09:57 PM   #3
BrianX
Member#: 1923
2000 2.5RS
BRP
I just got mine done.
he dealer charged $385 -10% + the extras I added (wiper blades, alignment, etc)...
BrianX is offline   Reply With Quote
Old 12-27-2001, 07:25 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
If you can do most of them at home, do them at home. I think the dealer charges way too much for a 30k service. I did all mine at home for under $100 for parts.
tmat3 is offline   Reply With Quote
Old 12-27-2001, 10:30 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
How do you dispose of a large quantity of brake fluid and coolant? That's my biggest pain with the 30k service. I spent over $400 on my Jeep's service and I'm not doing it again. It's not worth the money because I can do most of it myself in an afternoon.
Tranny/differential gear oil gets recycled with the motor oil at the local auto parts store, but what about the other stuff?
Old 12-27-2001, 11:20 AM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
For the coolant, if there is a WalMart, KMart, or Sears with a car care place, then they will take it. Also, try places like Midas too.
As for the brake fluid, I just threw it away although I'm not supposed to.
Old 12-28-2001, 12:22 AM   #7
tcarter
Member#: 12366
I would call before hauling that mess around and getting denied..
tcarter is offline   Reply With Quote
30000 mile service help Stilletto South East Region Forum 8 05-14-2003 06:54 AM
30000 mile service aidrock Tri-State Area Forum 4 02-23-2003 05:01 PM
where should i go for 30000 mile service [mr.]impreza Bay Area Impreza Club Forum -- BAIC 8 03-08-2002 04:06 PM
