10-20-2000, 08:28 PM | #1 |
Member#: 438
W. Canada
Vehicle:2004 STi White on Gold |
A Good and Bad Day
Well first the bad news.
I had to replace the Legacy GT rims back on my wife's car tonight Now my RS looks like all the others. Good News!!! I installed the PDM Racing Intake this afternoon. I had about twenty minutes to spare so I decided to see how quickly I could install the intake. The wind was really blowing here today and a high of maybe 4C, but felt more like -4C. Anyway, I removed the three bolts that Ashton told me to remove and then quickly reefed on the end connecting to the 90 before the filter box. The whole plastic intake thingy came off in three seconds. Next, I cut the blue 1/2" silicon hosing on one side so it would slip over the lip in the hole in the fender. Placed the hosing over the hole lip then placed the silicon 2" to 3" adapter on to the filter box elbow and then stuck the PDM 3" Aluminun intake into the fender hole and pushed it over to the silcon adapter then fastended everything up. Next I disconnected the battery terminals held the two ends together for about 30 seconds (for a quicky ECU reset) and then put the terminals back on. Whole thing from start to finish took MAYBE 15 minutes with one rachet, 10mm socket, 12mm socket, one 12" socket extension, screw driver, and an exacto knife to slice the 1/2" silcon hose on one side. Car started with no problem, no effect on idle quality whatsoever. Let the car idle for about 3 minutes then drove the car. First impression about the intake? YEEEEEEHAAAAAAA!!!! What a fantastic melody this thing makes. At less than half throttle, it sounds total stock no matter what the RPM. Do a few WOT pulls above 3000rpm, however, and the sound under the hood is simply astounding. I think my favourite is a WOT pull in third gear going from 4000rpm to 5500rpm...simply glorious!!! What a hoot!!! I only hope it sounds this way from the outside of the car. My butt dyno tells me no loss and no gain, but the car definately makes me grin that much more. If you have a MY00 or MY01, you have GOT to get this intake. Thanks PDM Racing!!!!
10-20-2000, 08:46 PM | #2 |
Member#: 1260
VIC
Vehicle:09 STi, DGM 04 WRX Stage 2, red |
Whenever I have reset the ECU ,the first time you try it, it starts then stalls immediately. Second time it fires up ok and improves. Are you sure you reset it ok. I have one of Larry's intakes and that is a definite power improvement (just ask Ashton).
10-20-2000, 09:01 PM | #3 |
Member#: 438
W. Canada
Thanks for the heads up Petrie. I'll try the ECU reset again tomorrow and see what happens.
10-20-2000, 11:25 PM | #4 |
Member#: 1465
Vehicle:2000 rs sedan brp |
COOl. now the head of Edmonton have installed intake.
sound like a really sweet mod ... let meet up again soon and let us check it out ^__^ how much is this intake again? seem like it make the car more fun @_@ |
10-21-2000, 06:12 AM | #5 |
Member#: 1839
VIC
glad to hear that you like it. when you reset the ecu, you are suppose to let it let it idle for 10 mins, i did mine in 5min, seens to work, but you have to turn off the ignition then restart it before driving. did you do that?
10-21-2000, 01:23 PM | #6 |
Member#: 438
W. Canada
bender,
Thanks for the heads-up. I'm at my office right now working so the car is in the parking lot withj the battery disconnected. The ECU should definately be reset by the time I get back (90+mins). I'll go back and start it about 20mins before I leave then restart it before I split. Cheers, MB |
Lifted thread! Post your lifted Subarus. How you did it..and the good and bad | Evil XT | Brakes, Steering & Suspension | 16 | 01-09-2010 05:42 PM |
OriginalSin and the Terrible, Horrible, No Good, Very Bad Day ... | OriginalSin | Off-Topic | 21 | 10-09-2009 03:14 PM |
Good and Bad day yesterday | Unabomber | Off-Topic | 11 | 04-18-2009 12:42 PM |
3 times the charm!Good and Bad news | Patrick L | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 01-16-2001 08:35 PM |
A Good and Bad Day | markus | Vancouver Impreza Club Forum -- VIC | 2 | 10-20-2000 10:40 PM |
