Notices
Old 06-12-2007, 01:18 AM   #1
beaun-nus
Member#: 134629
'99 2.5rs
black
Default wrx fuel pump in 99rs???
will a wrx fuel pump work in a rs or will i need to get hardware for it to work?
beaun-nus is offline   Reply With Quote
Old 06-12-2007, 10:54 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Why do you want it?
Old 06-12-2007, 12:54 PM   #3
beaun-nus
Member#: 134629
'99 2.5rs
black
Default pump
just to see if it will work instead of a walbro
Old 06-12-2007, 01:11 PM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Use an STi pump for a bit more flow. I found mine slightly used for $30.
-Rob
rob is offline   Reply With Quote
Old 06-12-2007, 01:40 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah but its like (actual numbers escape me at the moment)
140-wrx
160-sti
vs 255
Old 06-12-2007, 01:48 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
I guess what I was trying to assess was need? You say in an RS, and not in a swapped RS. I ruined an engine in my RS because I overfueled it. It was fine when the engine was stock, but once I put on a built set of heads, the ECU overcompensated and my cylinders got washed down and contaminated my oil in a bad way. So, I reiterate, why do you want this pump?
Old 06-12-2007, 05:04 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
140-wrx
160-sti
vs 255
It's cheaper, quieter and flows more than enough fuel for 550 cc/min applications.
And Matt's right, I am assuming you are talking about an engine swap here.
Old 06-12-2007, 07:39 PM   #8
beaun-nus
Member#: 134629
'99 2.5rs
black
im doing a wrx swap and was just curios if they work. trying to keep the costs down
wrx fuel pump in 98 impreza L? rufracer Normally Aspirated Powertrain 6 04-08-2007 12:59 PM
2002 wrx fuel pump in gc8? billyr2.5 Normally Aspirated Powertrain 10 01-22-2006 11:40 AM
STi fuel pump vs. WRX fuel pump WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-02-2005 08:05 PM
TRADE: stock WRX fuel pump for 2.5RS fuel pump. Riverside CA RyansJDMgc8 Private 'For Sale' Classifieds 0 07-05-2004 06:47 PM
WRX fuel pump in 98 RS? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-30-2004 10:56 AM
