Old 06-12-2007, 01:23 PM   #1
cooleyjb
Member#: 55727
#533 Spec Racer Ford
Default Check your lugs
cooleyjb is offline   Reply With Quote
Old 06-12-2007, 01:25 PM   #2
Chiketkd
Member#: 71634
In hibernation...
Oh snap!
CN: SM2 RX-7 looses all four wheels within first 50 yards of an autoX.
Chiketkd is offline   Reply With Quote
Old 06-12-2007, 01:28 PM   #3
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
just saw this on the GRM board..pretty funny
STiShawn is offline   Reply With Quote
Old 06-12-2007, 01:33 PM   #4
Impreza01
Member#: 152
2002 Impreza WRX
I wonder how much the damages to the car cost.
Impreza01 is offline   Reply With Quote
Old 06-12-2007, 01:49 PM   #5
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
ooof
sachilles is offline   Reply With Quote
Old 06-12-2007, 01:54 PM   #6
Protege Menace
Member#: 41950
faq u rug
in the OT thread on this video it was pretty much decided that it wasnt because of loose lugs, but incorrect sized ones or oens that all sheared off .
Protege Menace is offline   Reply With Quote
Old 06-12-2007, 01:57 PM   #7
Chiketkd
Member#: 71634
In hibernation...
I wonder how they removed the car. Would probably have to literally drag it up onto a flatbed trailer.
Old 06-12-2007, 02:09 PM   #8
Impreza01
Member#: 152
2002 Impreza WRX
I doubt a guy campaigning an SM2 RX7 with Enkei RPF-1s shod with D.O.T. R-compounds will pick incorrect lugnuts. As later mentioned in the thread, some of the members there are backtracking on the idea of sheared off lugnuts.
Old 06-12-2007, 02:17 PM   #9
remowgn
Member#: 41149
09 FXT
SSM
You can hear a guy in the video say "these lugs are the wrong size." That's probably where people are getting it from. At the speed that it happened, it would be impossible for that many studs to shear off... there has to be something else systematically wrong. I've seen cars break studs at an autocross, and even with 275 R-comps, it takes quite a bit to launch a wheel off a car... let alone all 4 at once!
remowgn is offline   Reply With Quote
Old 06-12-2007, 02:18 PM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
wow...I know this region..and race with them ever so often...The BSP Porsche in the background is my direct competition....and has co-driven my car on numerous occasions...
SM2 RX7..looks familiar....
sux for him..
Bill
Old 06-12-2007, 02:25 PM   #11
Impreza01
Member#: 152
2002 Impreza WRX
Didn't listen to the audio. I was thinking along the same lines though. It's hard for all the lugs to shear off. I'm thinking what the guy did wasn't even finger-tightening the lugs, but just got enough for the lugs to catch thread. He probably thought it was going to hit them all with an impact gun or deep socket wrench later.
Old 06-12-2007, 02:37 PM   #12
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
I tend to agree with you.
Still if they were that loose, you'd think you might hear it even while staging.
Wonder how they tech stuff there, if they have a season long tech program, I can see that getting through. If not, that should have been caught.
I feel bad for the guy....made a mistake and now its all over the interweb.
I'm assuming that was his first run of the day. If not, that would add a little more credibility to the bad lug nut argument.
Old 06-12-2007, 03:42 PM   #13
go_speed_go
Member#: 151257
Hello all,
I was at the event and know the guy who owns the car. (No it wasn't me)
I was in the paddock area next to him changing wheels at the same time as him. I watched him torque all of them. I even borrowed his torque wrench to tighten mine (I always forget something after I get on the road).
He went to a wheel/tire business and asked for spline drive lug nuts for his particular make/model/year car for the Enkeis, and that's what they gave him. He did not purchase the tires or wheels from them, just the lug nuts.
The lug nuts where sheared off the studs. Several members lifted a corner of the car to slide a jack underneath it. With a few more jacks, blocks of wood, etc, they were able to mount the stock wheels and stock lugs nuts (at least 3 per wheel) back on, torque them and drive the car off course. The design of the car, possilbly for aerodynamics, tucks all mechanicals on the underside a little higher than the body line, or lowest part of the brake rotors. Not even the exhaust was really scratched.
I'm not a mechanic, but the mechanics theories there was that the lug nuts where the incorrect size, but they were just small enough to grip the outer edge of the threads (as I mentioned, they torqued to 75-80 ft/lbs without complaint).
Hopefully, the only damage is to the body and brakes.
go_speed_go is offline   Reply With Quote
Old 06-12-2007, 04:56 PM   #14
motoring
Member#: 49245
1990 Mazda Maita
screaming pumpkin
It is possible they gave him 1/2 nuts instead of the 12x1.5. the size difference is enough they may fit together but would have zero strength.
motoring is offline   Reply With Quote
Old 06-12-2007, 05:13 PM   #15
go_speed_go
Member#: 151257
That sounds very possible.
Old 06-12-2007, 05:52 PM   #16
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Man that suxs!!!
I like how the video shows that he put his handbrake up after this all happened.
boundy3 is offline   Reply With Quote
Old 06-12-2007, 06:08 PM   #17
heet
Member#: 66807
2008 LegacyGT Spec B
Originally Posted by boundy3 View Post
Man that suxs!!!
the parking brake was a nice touch
heet is offline   Reply With Quote
Old 06-12-2007, 10:28 PM   #18
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Impreza lugs are M12x1.25.
nhluhr is offline   Reply With Quote
Old 06-13-2007, 08:38 AM   #19
IT Swift
Member#: 125853
2013 Impreza Sport
Red
So?
IT Swift is offline   Reply With Quote
Old 06-13-2007, 09:11 AM   #20
wileecoyote
Member#: 82610
2003 WRX GDA
Black Carbonfibre
Originally Posted by IT Swift View Post
So?
So all our impreza friends will not buy the wrong nuts after seeing that post.
wileecoyote is offline   Reply With Quote
Old 06-13-2007, 12:21 PM   #21
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I truly do feel for the guy, and maybe I am evil, but I laughed incredibly hard and loud at that video for a good solid minute.
Sucks. But damn funny in video form.
jblaine is offline   Reply With Quote
Old 06-13-2007, 03:46 PM   #22
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
exactly. and yes, i understand that the person i quoted didn't say imprezas have 1.5's... but this is an impreza forum and stuff comes up in searches all the time.
Old 06-13-2007, 08:00 PM   #23
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Odd that they all came off at the same time...
Feel sorry for the guy. Hopefully not too much was damaged.
Mind is offline   Reply With Quote
Post Your Lugs. rally_on Member's Car Gallery 514 04-14-2014 12:27 AM
Can anyone lend me your lug key to your Muteki SR35 Lug Nuts chop204 Tri-State Area Forum 0 09-09-2009 10:50 PM
so how fast is your internet. my results, plus check yours and compare STEALTH-WRX Off-Topic 35 07-18-2003 01:16 AM
Jonaton, check your Pm's. Roger, yours are full.. subarurabbit New England Impreza Club Forum -- NESIC 3 12-30-2001 12:46 PM
