Old 06-12-2007, 05:30 PM   #1
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Default Not hitting target boost on stage 1 map
Ok Flashed my car to stage 1, 2 nights ago. It made a huge difference on general drivability and smoothness. But After datalogging Im only seeing 13.2 psi at wot.According to the map target boost should be 14.75 at 3000rpm and 16.5 by 3500rpm. I have the log on my laptop and can post it later if needed.
-Bruce
Mr.Krinkle is offline   Reply With Quote
Old 06-12-2007, 10:26 PM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
-Bruce
Are you only seeing 13.2 psi at 100% throttle throughout the RPM range or at redline? You might need to shorten up on the WG arm a few turns.
blkscooby is offline   Reply With Quote
Old 06-12-2007, 11:45 PM   #3
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
13.2 at WOT throughout the rpm range. Do you think I need to shorten the WG arm abit??? I didn't think that would be needed at stage 1.
Old 06-13-2007, 12:01 AM   #4
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Last edited by Mr.Krinkle; 06-13-2007 at 12:06 AM. Reason: Stupid log wont post!!!!
Old 06-13-2007, 08:10 AM   #5
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
yes. shorten it a few turns at a time and take some logs to see where you are at with the boost. I recently had a similiar low boost situation and shortened the WG actuator arm 2.5 turns and now am solidly getting 15+ psi.
Brock31 is offline   Reply With Quote
Old 06-13-2007, 09:20 AM   #6
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Great I'll give that a shot and log some on my way home tonight.I was starting to get a bit pissed on the fact that the ECU wasn't learning correctly after the quick learn trick....lol. One more question what kindof range should I be looking for WG duty cycles?
Old 06-13-2007, 09:36 AM   #7
wage0052
Member#: 127556
2006 WRX
RomRaided.
Are your WGDC's pegged at 90-100%?
wage0052 is offline   Reply With Quote
Old 06-13-2007, 09:40 AM   #8
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Most I've seen is 80% and nothing more.
Old 06-13-2007, 09:49 AM   #9
wage0052
Member#: 127556
2006 WRX
RomRaided.
Is this on an '02 WRX? What map are you using?
Old 06-13-2007, 09:52 AM   #10
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Yep 02 wrx wagon.....stock other than the map that was loaded now three days ago. osecuroms.org free stage1 map. acording to the tables when I look at the map I should be hitting 16.5 by 3000rpms.
Old 06-13-2007, 10:27 AM   #11
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yeah, evasive likes to have those boost targets way up there. I'd suggest doing a little fine tuning of that map. 14-14.5 PSI is about all you're going to get for a stage 1 map, assuming the exhaust is stock. I'd say that with the way his free maps are set up, you're going to end up with some funky boost behavior through the whole high throttle areas.
Personally, I'd start by lowering the boost target, and then playing with those WGDC tables until you're able to hit a lower target boost across the whole RPM range. I'm not a big fan of adjusting the WG arm.
Old 06-13-2007, 11:41 AM   #12
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
+1, you should only adjust the WG arm if you are still not hitting your targets with ~100% WGDC.
brettm is offline   Reply With Quote
Old 06-13-2007, 12:20 PM   #13
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
All right then....Thanks for the help I'll start playing around with the tables then and see what happens.
Old 06-14-2007, 02:04 PM   #14
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
I adjusted my WG duty cycle tables at 75% and 100% throttle up 10%. Im still only seeing 14.2psi. I am starting to get up to boost quicker though, but WG is pegged so I may have to adjust the arm to see any more,looking back at my old logging when I was completly stock I was only seeing 13.6psi. Does anyone else think I should adjust the arm for this?
Old 06-14-2007, 06:46 PM   #15
wage0052
Member#: 127556
2006 WRX
RomRaided.
I guess my '06 is supposed to make a tad less PSI, but I'd say 14+ is quite good for a stock car.
Old 06-14-2007, 09:12 PM   #16
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
what's your elevation?
06rexwagon is offline   Reply With Quote
Old 06-14-2007, 10:57 PM   #17
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
elevation is 1400 ft.
today after a reloading the map the best I could come upp with is 15.08psi. I think Im gonna adjust the wg abit this weekend and see what I can come up with. I did flash my Buddies car today to see if there was a difference, first run on the log indicated 16.4 psi. he is completly stock other than a 3inch cat-back.So as always I blame my car.
Old 06-16-2007, 05:37 PM   #18
wage0052
Member#: 127556
2006 WRX
RomRaided.
From my datalogging, I can tell you that a catback will significantly affect your boost, especially at high loads.
Old 06-16-2007, 06:04 PM   #19
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
alright then........that settles it then. I'll dail my boost table back down to 15.00,since I'll be getting a TBE and going to stage 2 at the end of the month anyway.........
Not hitting target boost 2004 wrx stage 2 wrxmuch? Engine Management & Tuning 11 02-28-2013 02:56 AM
Not hitting target boost on Gabedude's stage 1 map NJ2.5RS Open Source Reflashes 19 08-12-2010 01:05 AM
Another Stage II MY02WRX Not Hitting Target Boost -AliasMunky3- AccessPort 2 09-04-2007 06:53 PM
XPT mapped VF34 not hitting target boost ptirmal Commercial ECU Reflashes 14 06-20-2007 01:04 PM
Stage 2 = not hitting target boost. t4nk AccessPort 3 04-12-2007 09:41 PM
