Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-12-2007, 07:58 PM   #1
tibor75
Member#: 23883
Default RPMs increase then drop after accelerating... is this normal?
I have a 2002 WRX sedan with 65K on it. No mods.
anyway, let's say I'm going around 65 mph in 5th gear. RPMs are around 2700. If I try to accelerate quickly, the RPMs shoot up to 3500 or so and then drop down back to 3000. If I try to accelerate gradually, this doens't happen and the RPMs go up without any rapid rise and drop. This happens in 4th gear too, and maybe 3rd. Usually when I'm right under 3000 RPM. I don't think it was doing this before, but I could be wrong (I am not even close to being an automotive expert)
I was in a front end accident about 6 weeks ago and did damage to the front of the car and coolent / air conditioning systems, etc. Since then, I've been paying more attention and maybe this is why I noticed this, but maybe it started then.
thanks!
tibor75 is offline   Reply With Quote
Old 06-12-2007, 08:07 PM   #2
TurbojonLS
Member#: 38772
2 Cars, No Bling
No, its not normal. Its a sign of a slipping clutch.
TurbojonLS is offline   Reply With Quote
Old 06-12-2007, 08:16 PM   #3
tube
Member#: 139485
2004 16g WRX DomTune
Java Black Pearl
If you had an automatic, I'd say it's normal... but you don't.
New clutch time!!!
tube is offline   Reply With Quote
Old 06-12-2007, 08:17 PM   #4
tibor75
Member#: 23883
Thanks. I did a few internet searches since I posted and that is what is seemed like.
Old 06-12-2007, 08:28 PM   #5
tibor75
Member#: 23883
BTW, I assume this is more related to my repeated burning of the clutch over 5 years than the front end accidnet I was in?
Old 06-12-2007, 09:08 PM   #6
Dhcheckeracer
Member#: 114227
03 B6 A4
DG
i had a front end wreck at like 6k and now at 15k my clutch did the same thing..insurance said it wasnt front end wreck so u gotta fork out for the new clutch
Dhcheckeracer is offline   Reply With Quote
Old 06-12-2007, 09:14 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
clutches are normal maintenance items. the mean life of one is probably around 70k, there are lots that go much higher, but also lots that die much, much sooner. (If you learned to drive stick on it, it is in the much sooner catagory)
Old 06-12-2007, 09:14 PM   #8
tibor75
Member#: 23883
Guilty as charged
Old 06-12-2007, 09:23 PM   #9
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
MT
MT_WRX is offline   Reply With Quote
Old 06-13-2007, 01:00 AM   #10
outlwstr
Member#: 102201
Like everyone said.. your clutch is slipping.. i couldnt figure what the hell was going on when my clutch was slipping just as u described yours
outlwstr is offline   Reply With Quote
Old 06-15-2007, 07:39 PM   #11
RallySoob
Member#: 74872
2006 STi
White/Black
Jee, wasn't the clutch being 'toasted' already established up top already?
OffTopic:
hey outlaw, is this the NASIOC you were saying that you have alot of credibility at?
*and this forum will be banning people on your behalf right? hmm...
And you said that the yahoo group: PDXWRX are cheezeballs, Do you know that they reside here as well?
Best keep your posting to a minimum unless it's prevalent
RallySoob is offline   Reply With Quote
Old 06-15-2007, 07:54 PM   #12
REX8
Member#: 24038
OffTopic:
Hmm... maybe you should as well...
You have an entire thread devoted to your credibility...
http://forums.nasioc.com/forums/show....php?t=1267732
Old 06-15-2007, 08:38 PM   #13
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
PWN3D
Serious pwnage.
MT
My first TURBO car. Is this normal? Carartist Newbies & FAQs 6 06-03-2010 07:50 PM
is this normal after installation subielover29 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-06-2010 01:08 AM
what is your idle RPM? - is this normal? cnriver2002 Impreza Forum 6 06-04-2008 03:18 AM
Is this normal after alignment? pleasenoSTIckershock Tire & Wheel 10 04-28-2004 05:23 PM
oil light came on for a second after oil change... is this normal? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-28-2003 11:07 PM
