Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 06-12-2007, 09:30 PM   #1
cardshark
Member#: 122792
2005 Impreza WRX
Obsidian Black Pearl
Default Help finding Wiring Diagram for A/F gauge install
Looking to install A/F Ratio, Boost and Oil Temp gauges. I know I'm looking for pin B-17 on the ECU to connect signal wire from A/F gauge. Searching around (yes even on Scoopymods) having trouble finding a diagram or picture that can show me where it is. Maybe also any diagram or pic I may need for Oil Temp gauge install.
Thanks in advance...
cardshark is offline   Reply With Quote
Old 06-13-2007, 12:14 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
if your A/F gauge connects to the ECU, take it back. the only wiring you want to tap into for A/F is ground, power, and light dimmer. narrowband a/f gauges connect to the stock o2 sensor, which is bad. it is useless for tuning, and worst case it could destroy your engine by affecting the o2 signals the ecu is receiving.
the other gauges, run the wires yourself. power, ground, dimmer are the only ones, and you can easily grab those from the clock &/or radio wires in the dash.
Old 06-13-2007, 12:22 AM   #3
cardshark
Member#: 122792
2005 Impreza WRX
Ok. I am hearing that advice from more than one source. So, if I buy an A/F Ratio gauge I want a Wide-Band? If so, do I need to install a different sensor for it? Where can I read on that?
Thanks
Old 06-13-2007, 01:10 PM   #4
Sub2ner
Member#: 103725
2005 Wrx
homework on narrow vs wideband is good
narrowband (what youve got) has its pros if you know what you want it for.
if you choose to use it:
purple wire goes to purplish wire from the rear 02 sensor
Sub2ner is offline   Reply With Quote
Old 06-13-2007, 04:12 PM   #5
cardshark
Member#: 122792
2005 Impreza WRX
Well I dont have anything yet so I free to do whatever. Thanks for the help. It sounds like Wide band is better, but my car is very mildly tuned.. To weld a new bung, buy a new sensor and buy a wideband gauge sounds like a chunk of change. I might just wait. A project for later.
Old 08-09-2007, 08:25 AM   #6
Sub2ner
Member#: 103725
2005 Wrx
if you are tuning, maybe checking things without datalogging, wideband is amazing.
however
if you are running something safe off the shelf (cobb map), have done mild things outside of the maps tune and want to see a/f while under wot and just listening for knock is nearly archaic, narrowband.
tis what i do
Old 08-09-2007, 03:33 PM   #7
cardshark
Member#: 122792
2005 Impreza WRX
Thanks for the tip. But at the expense and effort of gauges, a pod, installing the correct way, I may just not. I'm only going to do stg 2. Maybe a STI TMIC at best. Seems like a lot of extra work just to have cool lights to look at. If I ever swap out the turbo, I'll be all over it.
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 01:12 AM
Need wiring diagram for 04 sti ocv solenoid sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-03-2010 05:59 PM
Help, need wireing diagram for 07 wrx GTIzzle07 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-31-2009 02:34 PM
Help: Looking for wiring diagram for blitz r115 gauge! dacatz Electrical & Lighting 2 05-31-2006 02:41 AM
wiring diagram for 02 wrx gauge cluster veightkiller Electrical & Lighting 0 12-27-2005 02:35 AM
