06-13-2007, 09:26 AM | #1 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
Trying to start the car
OK, we got everything finally back together last night and go to start the car. Load up the Hydra and see Phil has a base map in the Hydra for me already. Cool. Went in, did the TPS and Wideband calibration. Turned off PWM 2 and 3 as Phil requested because I don't have AVCS now. And finally changed the Injector load response to 16 ohms as i'm using WRX high impedence injectors.
Everything seems normal. Fuel pump primes and we are off. Crank the car....nothing. Crank some more....nothing. Not a pop, not a backfire.....nothing. Pulled the plugs out and they looked brand new...no fuel on them at all. So now we know that the injectors aren't firing. So what's the deal?? When I'm cranking, the stuff on the left of the Hydra screen is showing the Hydra outputting like 4ms of fuel....but no way am I getting that. Mod List: Wiseco Pistons Carrillo Rods OEM Main Bearings Clevitte Rod Bearings Axis Racing P&P Heads 1mm oversized valves and dual valve springs Big Kelford non-AVCS cams 35R with all the other BS to go with it Dual Walbros Deatcheworks (sp?) 1150cc injectors Perrin Fuel Rails I put an email in to Phil last night. Hopefully I'll get a chance to talk with him today.
06-13-2007, 09:59 AM | #2 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
I don't think 4ms is enough to get the motor to start... While cranking, I usually see 10-13ms. With your injectors, I would think that you would want to see at least 8-10ms.
06-13-2007, 11:30 PM | #3 |
Member#: 44351
p0wn3d by the low battery voltage again. That's 2 Hydra cars that have got me.
Damn she sounds nasty!! |
06-14-2007, 10:05 AM | #4 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
He's running 1000cc injectors so 4 ms is likely enough. Always check battery voltage first and if 10v or less, charge it up, and then if still not successful run the crank trigger test to make sure the cam and crank are reading properly.
I've been on the dyno for the last couple days but I'm glad you got it running on your own. Thanks, Phil www.elementtuning.com |
What's your oppinion? Local forum creep trying to start national car forum... | DeusExMachina | Off-Topic | 35 | 02-01-2007 10:33 PM |
What do you need to start the car without the radio turning off? | jsbush | Electrical & Lighting | 13 | 12-06-2006 03:11 PM |
PA: Tried to wax the car yesterday. Need a pro detailer... | Siper2 | Mid Atlantic Impreza Club -- MAIC | 19 | 05-11-2005 02:33 PM |
Tried to start the motor tonight...No luck | SloRice | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 24 | 04-16-2005 11:19 AM |
Why must I disengage the clutch to start the car? | Bimmer | Transmission (AT/MT) & Driveline | 13 | 06-14-2002 05:36 PM |
