06-14-2007, 09:36 AM | #1 |
Member#: 82146
South East
Vehicle:2005 Legacy GT OBP |
how long would it take to go back to factory from a hydra ems?
would it be possible to use the hydra most of the time but for maybe 1 special week of the year go back to an ecutek tune on a stock ems?
how long would it take to go back??? i like the ability of the hydra to control 8 injectors and that it is supposed to be much easier to tune @ higher hp than a piggy back etc. but still want that sticker on my car.
06-14-2007, 10:05 AM | #2 |
Member#: 58251
Vehicle:2004 Sti GT35R 530whp @ 27psi |
First, I dont think running 8 injectors is a lvery popular idea, especially when the hydra is so good at controlling 1000+cc injectors. Most end up going with 4 larger injectors.
Anyway, past that, assuming that you have an ECU capable of running your car, it would take less than 30 minutes to swap out the hydra for a stock ECU. It is as simple as pulling up the carpet, removing the 3 bolts that hold down the kick panel, un bolting the hydra from the floorpan, unplugging the ECM harness, mounting the stock ECU back, and plugging the hydra's MAP sensor tube so you dont have a leak. The place you run in to problems are MAF sensor (which hydra only uses as an IAT, but stock ECU needs it for fuel mapping), and the other various emissions devices that most Hydra users toss in the trash. |
06-14-2007, 10:06 AM | #3 |
Member#: 82146
South East
Thanks I Appreciate It.
06-14-2007, 10:46 AM | #4 |
Member#: 18384
Vehicle:2004 STi: 580 AWHP Java Black Pearl |
You don't even need to pop for an ECUTEK, just do an OpenECU reflash (free besides a $79 cable and any professional tuning needed). You can have most any CELs disabled you like and adjust the fueling for your MAF & Injector setup.
I'm running this on my built GT35R build right now for break-in. Russ |
If you had to organize all your email from your main account how long would it take? | Cjchaps | Off-Topic | 13 | 02-04-2009 02:49 PM |
How long would it take for a leaking pilot light to fill an apartment? | Strider | Off-Topic | 23 | 10-17-2008 07:51 PM |
Let's say you're a home builder. How long would it take you to finish this work? | Yoo Shin | Off-Topic | 25 | 11-30-2007 10:31 AM |
How long would it take to install struts? | Googs211 | Brakes, Steering & Suspension | 10 | 11-20-2005 05:04 PM |
How long would it take to drive from Seattle to Spokane? | jcdrenguis | North West Impreza Club Forum -- NWIC | 25 | 03-05-2005 08:21 PM |
