Old 06-14-2007, 06:59 PM   #1
IntenseWagon
Member#: 144540
2016 WRX Limited
Default A/C Expansion valve
So, my A/C has been dead since i bought my car about 6 months ago, and its 105 degrees where im at today. i HAVE to get it fixed.
Symptoms: Turn on A/C, compressor spins, fan blows, but i hear a hissing sound (must like a BPV or BOV in recirc mode) constantly while the A/C is running. The air is not cold, but not super hot, just about ambient outside temp. I had a buddy check it with his A/C system recharger, and the High pressure line stays normal, but after a second (the same time the air begins to blow hotter) the Low pressure line goes into vacuum. His idea was that there was a blockage somewhere, which was causing the line to go into vacuum. (DUH). But im not sure whether to check my A/C dryer first...??? or my Expansion valve (WAYY under the dash, PITA to get out)....??? or what should i check first???
Its a MY02 BLACK wagon, so its hotter than he!! right now.
PLEASE help!!
btw, ive searched for 20 mins for threads about this and cant find any answers. same questions as mine, but no answers.
thanks for your help.
-Brian
IntenseWagon is offline   Reply With Quote
Old 06-15-2007, 02:32 AM   #2
IntenseWagon
Member#: 144540
2016 WRX Limited
bump!
Old 06-15-2007, 08:48 AM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
First thing to do would be verify you have the right amount of refridgerant in the system by evacuating and recharging. Start with the basics then go from there.
Old 06-30-2007, 01:48 AM   #4
kdogae86
Member#: 99139
02 wrx
bluey
i hear that noise too and just topped off the juice.i think its the lack of pressure through the expansion valve.dunno though,just knows it works.
kdog
kdogae86 is offline   Reply With Quote
Any mechanic in Morris County that can replace Expansion Valve? Bran2a Tri-State Area Forum 8 06-24-2007 07:27 PM
ac expansion valve the_virus Private 'Wanted' Classifieds 1 06-05-2007 10:24 AM
where is the expansion valve on a wrx? eddie1982 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-28-2006 09:21 PM
Need pics of where the expansion valve is? eddie1982 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-15-2006 01:20 PM
Replacing A/C expansion valve? multiplexer Service & Maintenance 14 07-28-2005 05:40 PM
