#1 |
Member#: 99205
Vehicle:2005 Impreza WRX Blue, Stars & pleques |
Hot coolant running through the throttle body will be directed around the throttle body instead of through it, this
bypass is for Cooler and denser air. And you will notice a warm instead of hot intake manifold when valve is closed. You can you use a plumbing shut off valve from home Depot or Lowes to toggle on and off. If you have the car in very cold climate's like Alaska you might want the valve. If the car will never see weather well below 0 degrees just reuse the 1/4 lines your be fine. All my car's have this mod and friend's car's as well never had any problems. As for decreased fuel economy I feel if you don't have a good engine tuner and worried about your MPG keep it stock.
Last edited by ColesSTi; 02-08-2012 at 10:46 PM. Reason: Update to verify ineffectualness |
#2 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
there IS definatly an old thread on this board about this mod. Its a free mod, but these guys are selling the parts you need to do it so i guess its worth it. time is a valuable asset right.. right.
Spend a few minutes searching, there IS a thread or two about this mod. Make sure these guys are selling you what you need. My guess is after you find the old threads you'll just go out and buy what you need yourself if anything. |
#3 |
Member#: 117741
NWIC
Vehicle:2012 STI Ltd SWP 2006 Saab 97x Arc |
Do not buy this. It is ridiculous.
You can buy the brass coupling at your local hardware store for like $3 and do the bypass yourself. Gains will be very very minimal too, not "6-8 HP at the wheels." Jesus. |
#4 |
Member#: 108222
BAIC
Vehicle:2002 WRX stage-x Midnight Black Pearl |
hahahah look at the "dyno runs"
#5 |
Big Ron
Moderator Member#: 18062
www.scoobymods.com has the instructions and this will NOT net you 5-10HP. I did it because it makes sense and it cost me like $2 for the fitting.
#6 |
Member#: 92003
South East
Vehicle:04 TDI Passat |
^^hmm live in alaska...probably shouldn't do this
#7 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
lol!!! I should've thought of selling this "mod" on ebay long ago.
did this mod before, nothing on the butt dyno. |
#8 |
Member#: 99205
Thanks, I will pick the stuff to do install at lowes today.
#9 |
Member#: 133936
W. Canada
Vehicle:2005 WRX Wagon Stage 4 Silver |
I didn't have to buy any fittings. The factory coolant hose will reach the other connection on the block without bending or binding.
#10 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Got pics?
#11 |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
#12 |
Member#: 38068
South East
Vehicle:03 WRX Wagon |
#13 |
Member#: 133936
W. Canada
Dude, you don't need to buy anything. if you're looking down at your block below the throttlebody there are too hose nipples. Simply take one of the hoses from the throttle body and connect those two coolent line hose nipples together. One of the two hoses on the throttlebody is too short. Use the other one. You can even reuse the hose clamp. Now paypal me $11.95. Gawd.
#14 |
NWIC
you can buy a couple large vacuum caps if you really want to 'cap off' the fittings on the throttle body... which really isn't a bad idea, but you can do the mod right now and then drive over to get the caps from any autozone.
#15 |
Member#: 98961
Vehicle:2003 WRX Black |
Yeah, plug it back in before winter. This is a common mod on integra's and civics too.
#16 |
NWIC
no need to hook it back up. The car runs JUST FINE without it in subfreezing temperatures.
#17 |
Member#: 120152
No pics?
#18 |
Member#: 99128
Vehicle:2005 SAAB 92x Black |
or plumb your washer fluid through TB to get warm water to clean windshield and maybe a few more HP gain
for cooling the TB |
#19 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
#20 |
Member#: 98961
You know, since the ECU can't measure a temperature difference at the manifold, it really shouldn't have any affect on power. On a Honda, the IAT sensor is after the throttle body so, the ECU can measure the difference.
#21 |
NWIC
since we are talking about heating the air prior to its entry to the combustion chamber, yes, it should make a difference.
#22 |
Member#: 116132
Vehicle:2006 wrx tr Stage II sgm Jorge tuned -RIP :( |
I think I will do this in the next couple of days... It will not hurt anything so why not...
The cooler the air charge the better so again why not!!!! |
#23 |
Member#: 19075
Vehicle:06 OBS STi MSPT Tuned Stg2 |
Someone get some pics up of this
#24 |
Member#: 116132
When I do this I'll try to get some decent pics....
#25 |
Member#: 107361
South East
Vehicle:Now, with 100% less trunk space! |
| Thread Tools | |
| Display Modes | |
| Throttle body coolant bypass problem? | SubasaurusWrex | Factory 2.0L Turbo Powertrain | 4 | 04-27-2006 02:05 PM |
| Throttle body coolant bypass = blocking flow instead of rerouting? | athakur999 | General Community | 7 | 04-13-2006 08:33 PM |
| Throttle body coolant path. | Aus_RS | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 04-26-2004 11:55 PM |
| Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? | Kostamojen | Normally Aspirated with bolt-on Forced Induction Powertrain | 35 | 02-22-2004 09:14 PM |
| Throttle Body coolant line mod | WRX Joe | Factory 2.0L Turbo Powertrain | 41 | 07-14-2002 11:55 AM |
