Old 06-20-2012, 07:36 AM   #251
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by UK-Wagon View Post
Its not a huge difference in temp
agreed.
but anything helps.
agreed.
So no....
Old 06-20-2012, 09:30 AM   #252
DDScooby
Member#: 161876
02 Impreza WRX
I asked my tuner (Chris @ EFI Logics) No gains whatsoever from this mod...
Added note to UK-Wagon, he's absolutely correct. I was born and raised in Alaska and unless you're North of the Arctic Circle then no TB is gonna stick due to weather outside. Where that notion came from is beyond me but people need to go back and learn about thermal dynamics and condensation properties with metals. :-/
Does it REALLY assist w/cold start ups? Maybe, but I don't see how, it'll heat up the intake charge about 3 minutes faster in weather below 32*(0*C)...so really? sticking? Cold start up? I don't buy it, but the idea is sound so why not just leave it alone, it doesn't hurt or gain you anything by just not touching it.
DDScooby is offline   Reply With Quote
Old 06-20-2012, 09:50 AM   #253
taejin
Member#: 318541
2011 WRX
Satin White Pearl
There seems to be an overall benefit (how much is still being argued...)
Im thinking this would be a much more beneficialmod for those in high temp areas... Az is usually 105 deg+ for the summer months (upward (of 115 certain days). I noticed my intake temps rise REALLY fast at idle (ie 30 degree jump in a matter of seconds) so I would think every little thing to help air temps in these types of climates would have even more benefit.
Im in for this one. Did it on my old civic with no freezing issues (did not see much benefit though lol) but it does make a lot of sense for a turbo car. Im gonna try anything at this point....
annoyedmycarisknocking.
taejin is offline   Reply With Quote
Old 06-20-2012, 10:05 AM   #254
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
chris needs to learn some physics.
it absolutely flabbergasts me that nobody understands engine tuning 101:
every little bit adds up.
it's not up for debate.
i guess that's why the real art of engine tuning is dead; people just slap on big turbos, big ics, and big injectors and call it done. meanwhile, smokey yunick rolls in his grave.
Old 06-20-2012, 03:35 PM   #255
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
For everyone who does not believe in this mod. Please go to your house and take your hot water heater outlet line and run it next to or touching the cold water line. Or take your AC compressor and put it in the sun or maybe get one of those propane heaters and heat the coolant lines. See how efficient or well things work out.
This mod is common sense whether you can prove HP gain or performance its common sense that removing heat will help.
Ernest is offline   Reply With Quote
Old 12-11-2012, 07:59 PM   #256
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
oops, posted in wrong thread, sorry.
Jessekrs123 is offline   Reply With Quote
Old 12-12-2012, 12:08 AM   #257
lechugas
Member#: 340370
Originally Posted by prometheum View Post
^^hmm live in alaska...probably shouldn't do this
^^ yeah dont do it
lechugas is offline   Reply With Quote
Old 12-12-2012, 06:43 AM   #258
hoffmanEstates
Member#: 122043
04 wagonier
psm
I have performed this 5 years ago when i was installing my larger tmic. Have had 0 issues and i been in central WI winters and Chicago summers. I notice during summer my TB is not "burn my hand off" hot. I wonder if you accompanied this mod with phenolic spacers ya just might get a whp or two....
hoffmanEstates is offline   Reply With Quote
Old 12-12-2012, 09:42 AM   #259
rkramer
Member#: 118209
2015 WRX Limitec
thought this thread would have died off long ago!
At WOT, air spends .00005 seconds passing through the throttle body. Any heating affect is going to be so inconsequential there isn't a dyno in the world that will be able to detect it. So yes, it is costing you power, like .0005 hp. (all numbers are completely made up)
But on the other side of the coin, doing this 'mod' WILL cost you mileage. Cold air is good for power when you are at WOT, but cold air costs you mileage when you aren't at WOT. Search around the hypermiler forums, they do hot air intakes! For normal city driving where you are doing a fair amount of idling, not having the heated air will cause more fuel to be dumped in, plain and simple. (numerous factors cause that, i'd suspect the poor atomization of the fuel is the leading one.) My own testing as well as many others supports this, when you do this mod your mileage will suffer.
As someone previously mentioned, you would get more of a power boost by removing your floormats. Of course, that would also increase your mileage. In the case of this mod, you get zero measurable increase in power, but will absolutely be able to document your mileage drop if you keep accurate records. (also depending on your driving, more stop and go and this would have a larger impact.)
Old 12-12-2012, 10:32 AM   #260
Faster_Gun
Member#: 180217
2001 Porsche 911 TT
1990 Nissan Skyline GTR
You're telling me you want hot air? Just run your compressor side to your throttle body. **** innercoolers. I mean... the air crosses through the turbo for like .00005 seconds so its probably the same temperature as ambient. You're going to get so many miles per gallon dude. It'll be sweet.
Just some thoughts off the top of my head:
The fact of the matter is everything adds up. More dense air is better because it holds more O2 per volume, hence why we run innercoolers and in any serious "Power Proven Bragging" thread ambient temperature and elevation are recorded. On top of that more O2 will result in a slightly lean condition. (Better MPG?) Further more this shares the same concept as the TGV to head spacers, all trying to reduce IAT at the heads via reduction in heat transfer.
Realize what the throttle body is connected to an intake manifold and some sort of piping, all of which the throttle body is going to try to do its best to heat up to 195*F. I would like to see data on OD plenum temps before and after this mod, with and without thermal spacers to the heads.
Will I expect to see 5-10awhp? Hell no.
Faster_Gun is offline   Reply With Quote
Old 12-12-2012, 12:46 PM   #261
DDScooby
Member#: 161876
02 Impreza WRX
For a daily driven street car that doesn't see a track, except once in a blue moon. Then this makes no sense to do. For people that do Time Attack, Straights and rally courses then yeah I can see this + every other little tweek to squeeze every ounce of power out of the motor to gain an additional ~20whp/10tq. Sure if you have the throttle body off to do another mod (i.e. TGV deletes, injectors, inlet/intake. etc...) then yeah, by all means. But hurting or benefiting isn't going to affect the butt dyno or longevity of the car. Either way...up to the end user to decide if he or she wants to do it.
Old 12-12-2012, 08:37 PM   #262
Ernest
Member#: 45076
Did it years ago - no harm, maybe no benefit. I am going with every little bit helps. Some times a take a **** before I drive and the car just flies!
Old 12-13-2012, 11:24 PM   #263
CalvinT
Member#: 329025
2002 WRX Wagon
I'd be hesitant to use any brass fittings in any coolant connections. There was an End Wrench article that warned against using coolant flushing machines. There were several reasons given. One was the possibility cross contamination with copper ions if the machine had been used on a vehicle with brass or copper radiators. It could cause a reaction with the Subaru coolant.
in November 2008 Subaru approved the Wynn PowerFlush III coolant exchange machine since it uses three tanks that allow it to perform a clean water flush but it seems to me the warning about or copper ions would still apply.
I'd go with aluminum, stainless steel or plastic rated for cooling system use.
CalvinT is offline   Reply With Quote
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Throttle body coolant path. Aus_RS Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-26-2004 11:55 PM
Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? Kostamojen Normally Aspirated with bolt-on Forced Induction Powertrain 35 02-22-2004 09:14 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
