Old 06-19-2007, 03:13 PM   #51
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Originally Posted by Mechie3 View Post
Hmm...I see two ports, one inlet and one outlet with only the TB in between and very little to complicate things. HMM...... Seems to me like you could do a custom "intercooler sprayer" mod...only use an ice filled tank to get some cold water to pump through that and set it up to only pump during boost. Simply pump water in one side and then drain back to the tank. Would that be Auto-x legal for any class? I know that IC sprayers are illegal, but this would almost be like an air to water intercooler.
Somehow, I don't think it would be worth the effort, either cost-wise or weight-wise. The coolant only runs through the IACV, so it wouldn't seem like it would be terribly effective at cooling your intake charge. Good thought though, I could be wrong...
firebox40dash5 is offline   Reply With Quote
Old 06-19-2007, 03:38 PM   #52
crazymikie
Member#: 56321
2006 Honda El Camino
Green
The one downside I've found is that I've had ice form on my throttle plate in the winter when I use my water/meth injection. I can tell, because the car will idle just a tad high after doing some pulls. If I let it sit long enough, the ice eventually melts and the plate closes fully.
Not a big deal, but probably worth mentioning.
crazymikie is offline   Reply With Quote
Old 06-19-2007, 03:45 PM   #53
sharkmonkey
Member#: 118566
2005 WRX
A very important point crazymikie, if you're injecting anything pre-TB, I either wouldn't do this mod (unless you live in places it doesn't freeze) or put a T-valve on one side and cross-connect the lines with another T so that you can flip the valve and bypass the TB when its warm out.
sharkmonkey is offline   Reply With Quote
Old 06-19-2007, 03:45 PM   #54
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
good reason to put the nozzle in the plenum, eh?
Old 06-19-2007, 03:57 PM   #55
Mechie3
Member#: 120152
It makes for a good project/time killer. I have a bump of washer pumps, fluid level sensors, and enough electrical components to do it without buying parts (except maybe a pressure sensor and tubes). Plus, if you do the IC sprayer and the TB at the same time...I dunno. Plus it'd be cool to say, "Oh,that light? That's for the TB cooling system"
Mechie3 is offline   Reply With Quote
Old 06-19-2007, 03:59 PM   #56
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Sounds like fun. If it works, I'll buy a pump from ya.
Old 06-19-2007, 04:20 PM   #57
Mechie3
Member#: 120152
^^ I just went to the junkyard and picked them up for about $5. Float sensors were found mostly on "high end" (read: buick, chrysler) cars and some newer ones (junk yard near me has mostly mid 90's domestic crap) and were $1 from 1 guy (listed as misc) and the next day they charged me $5 for electrical components.
Old 06-19-2007, 05:10 PM   #58
crazymikie
Member#: 56321
Green
Maybe if the WRX manifold actually had a plenum I could put it in there
I'll see if I can fix that......
Old 06-19-2007, 05:21 PM   #59
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Mine has a plenum...
Old 06-19-2007, 05:30 PM   #60
crazymikie
Member#: 56321
Green
I was just joking about the small plenum. Just kidding around.
Old 06-19-2007, 11:37 PM   #61
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
EDIT: 06grayrex, have you experienced the TB failure they spoke of on clubwrx with the spec v's?
No I have not experienced and TB failure as of yet, nor do I expect any.. One guy with a different make/model/year doesn't raise an alarm. Now if there were 80-100+ people that own WRX/STIs reporting TB failures due to icing because of bypassing the coolant line then I would reconsider.
What do all of these people think happens anyhow in the winter time when the car that has been sitting overnight and they start their cars and just drive off with out letting their cars warm up? The coolant is just above freezing and it takes while for the coolant to warm up and the TB is not icing up. So how is this any different?????...........WAKE UP PEOPLE!!!!!!!!!!!!
Originally Posted by hoonee46 View Post
'06s are drive by wire? may cause a $750 problem (TB sensor failure)?? thought I read it on that other thread, follow link and check it out before you go on.
It sound like this person got raped by the dealer because he could have bought the sensor if it failed and replaced it himself. I think the TB failing was just a coincidence because of a faulty designed of the TB sensor, and not because the coolant line being bypassed......
06grayrex is offline   Reply With Quote
Old 06-20-2007, 12:34 AM   #62
06grayrex
Member#: 116132
AH CRAP!!!!!! My car froze up in the middle of June in the 85 degree weather!!!!!! I will never bypass my coolant lines on the TB again
http://www.pbase.com/scherrer/image/39280661
Old 06-20-2007, 08:03 AM   #63
Mechie3
Member#: 120152
^^HAHA You moron! You "scared" me for a little bit. While doing a turbo inlet install last night I did this mod. good thing my car is still in pieces thoughs so I didn't drive it.
then I clicked the link
nice!
Old 06-20-2007, 08:09 AM   #64
06grayrex
Member#: 116132
I thought it was appropriate. I'm glad you clicked on the link before freaking out.
Old 06-20-2007, 08:31 AM   #65
Mechie3
Member#: 120152
hehe...me too! I figured given the URL it had to be a joke of some sort.
Old 06-20-2007, 08:52 AM   #66
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
http://i150.photobucket.com/albums/s...x/IMG_1722.jpg
Would the coolant not leak out of these "RED" caps? or am I being a complete dumba$$
Ricey
Rice Devil is offline   Reply With Quote
Old 06-20-2007, 08:57 AM   #67
strohausii
Member#: 26770
'02 WRX
midnight black
lol, ice like that the damn car is welded to the ground!
strohausii is offline   Reply With Quote
Old 06-20-2007, 08:58 AM   #68
strohausii
Member#: 26770
'02 WRX
midnight black
Ricey
Nawh, not a dumb question, but was eventual.
One cap is the inlet, the other is the outlet; therefore, there is nothing to be leaked due to "BYPASSED" joining of the 2 disconnected hoses with the double barb coupling.
Old 06-20-2007, 09:07 AM   #69
06grayrex
Member#: 116132
I would of used black caps to give it a more stock look but the red ones fit the best and really highlights the which ports are to be capped off.
Old 06-20-2007, 09:22 AM   #70
Mechie3
Member#: 120152
Red=bling bling
black=stock
Old 06-20-2007, 09:47 AM   #71
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah the caps are just to keep dirt/etc out of the (now empty) coolant passage in the throttle body. The coolant is no longer in there.
nhluhr is offline   Reply With Quote
Old 06-20-2007, 10:52 AM   #72
sharkmonkey
Member#: 118566
2005 WRX
I did it last night and could tell a difference. Drove the car around yesterday, got out and put my hand on the intake manifold. I could just barely keep my hand on it so it was probably around 120-130 degrees. Did the mod after that, drove it this morning to work and checked it and it was just above ambient i.e. cool to the touch. I had the phenolic spacers in for both checks.
Granted, the ambient temp was probably 10-15 degrees different but with both (bypass + spacers) I'd say it makes a big difference. I'm just glad I found the source of the heat my manifold was getting, I couldn't figure out why the thing was still hot to the touch even with the spacers.
Old 06-20-2007, 11:13 PM   #73
06grayrex
Member#: 116132
Glad to see you have seen good results also with this mod. I do not regret doing this mod at all. I may have to look at doing the phenolic spacers in the future, maybe when it's turbo up grade time.
Old 06-21-2007, 06:08 AM   #74
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Shucks, I guess I'll have to try this when I do my turbo swap this weekend.
For something so easily done (and reversed if need be), why not?
Spenk is offline   Reply With Quote
Old 06-21-2007, 08:15 AM   #75
Davenow
Member#: 23676
Do the bypass, then on the coldest day of the next winter, I want you to drive your car for 10 min, and stay completely out of boost, so that NO compressed air goes through it. Then stop, get out, and put your hand directly on your throttlebody and hold it there.
Then go to the emergency room to deal with the burns. Yes we have heard of throttle body icing. Its the IMAGINARY condition (on subbies) that people who dont put a lot of thought into the subject keep talking about. Even with no hot coolant or boost, the throttle body is directly bolted to the intake manifold. Both get VERY hot. Before anyone says "But it will freeze when you arent running, and when you come out to your car in the morning, the tbody will be frozen!"
Ok then explain what magical forces will make the coolant be hot enough (or even remotely warm ) after sitting all night to keep it from freezing
Here is the reality, I know the people who spout about things like tbody icing dont LIKE things like reality, but here it is. People have been doing this mod for years. YEARS. Not once, ever, has a subbie had the tbody ice up. Never. Not one.
Now, with phenolic spacers you will not get the leaving flesh stuck sizzling on the tbody effect, but you still are never going to ice up.
** This info does not apply to those using water injection. Although I find it almost impossible to believe that anyone with water/meth would have it happen, because meth is antifreeze. Unless they are running a way low% mix. If it was anyone but mikie that said it happened I would call them a liar. Since it WAS mikie, I just scratch my head in curiosity. Still not convinced and think its something else though.
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Throttle body coolant path. Aus_RS Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-26-2004 11:55 PM
Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? Kostamojen Normally Aspirated with bolt-on Forced Induction Powertrain 35 02-22-2004 09:14 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
