#151 | |
Member#: 71647
Vehicle:2002 Bug iD |
#152 |
Member#: 71647
i noticed that there is a sensor in my throttle body i'm guessing one is the throttle flap position sensor and the other sensor is for the coolant running thru it.
this sensor is like right on top of my throttle body, if i do this mod, then will my engine temp sensor in my speedometer stay cold since there is no coolant flowing thru? |
#153 |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
There is no temperature sensor on the throttle.
#154 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
#155 |
Member#: 71647
#156 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
#157 |
Member#: 32792
NESIC
iirc, the iacv has 4 wires. i'm sure the map sensor has 3.
either one is fairly important to the car! ![]() |
#158 |
Member#: 116132
Vehicle:2006 wrx tr Stage II sgm Jorge tuned -RIP :( |
So where is all the people complaining about their TBs freezing up this winter?
OH, I forgot there are none.....I haven't seen one case of it....Has anyone else? ![]() |
#159 |
Member#: 7164
Vehicle:---> Spoiler alert: Everyone dies at the end. |
#160 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
just un-did this mod yesterday.... it was a pain to take the hoses off of coupler because it was almost fused into one piece. Plan to do it again when summer comes.
#161 |
Member#: 142029
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
#162 |
Member#: 32792
NESIC
#163 |
Member#: 118209
Vehicle:2002 WRX Sedan |
#164 |
Member#: 142029
yeah I'm sure your drop in mileage was because of that
#165 |
Member#: 118209
trust me it did. I keep very close records, as well as watch mileage with my scangauge. air that is TOO cold can cause partial combustion of the fuel. it doesn't atomize as well and sticks together.
You have noticed how NOBODY has had any issues with freezing? ever think that maybe that coolant isn't even there for freezing, but to help with cold weather emissions? |
#166 |
Member#: 32459
mine dropped a little also, but I suspect it is due to bad O2 sensor. New O2 is on its way... damn expensive at $160 shipped.
#167 | |
Member#: 32792
NESIC
if your theory is correct you'll get even better mileage with a blocked off TMIC. try it and see. |
#168 |
Member#: 125529
Vehicle:02 WRX 18G EJ205 1/4 mi stock block record |
For those of you who are worried about "freezing" in cold weather or poor gas mileage in the winter its seems most of you are somewhat technically minded.
Here is a suggestion for you. Grab some EXTRA fittings, hose and a valve set of some sort. Make it a SWITCHABLE bypass. Then you can simply rotate the valve and flow coolant thru your TB for your "emmisions" or bypass it with the valve for the "power" setting. This would also be a much more consistant way to test if it effects MPG/POWER as the other external conditions likely would not be changing as much (IE. last month I got XX MPG, now I dont. Must be the TB coolant bypass mod.---> but its COMPLETELY different weather out, got different fuel, etc.) If I am bored next time I have my TMIC off I will try to make this and take some pics. I would like to see back to back dyno pulls with this switchable bypass as well |
#169 |
Member#: 50993
Vehicle:02 WRX Wagon 2.5/Blouch Dom 3/Meth/6sp |
I read the entire post and remember only one car with WI/Meth. I use meth and I'm still not sure if I can do this mod? So I'm asking, is it ok?
Rexfan |
#170 | |
Member#: 116132
#171 |
Member#: 167272
Vehicle:2004 STi Aspen White |
well i'm going to do this today , but after reading every single post no one said anything about what is the proper plug to use to cap off the metal lines . i don't want to run one side to the other .
#172 |
NWIC
you can get some large rubber vacuum caps from the hardwear store. with the TB bypassed, there is no pressure (and no liquid) in the TB so you just need to keep dust/grit from getting in there.
#173 | |
Member#: 50993
#174 |
Member#: 144027
NWIC
Vehicle:2003 wrx blue |
#175 |
Member#: 121796
Vehicle:2005 Blue WRX Sedan In Subaru I Trust! |
If it was anyone but mikie that said it happened I would call them a liar. Since it WAS mikie, I just scratch my head in curiosity. Still not convinced and think its something else though.[/quote]
Hahaa, nice way to end the rant! |
| Thread Tools | |
| Display Modes | |
| Throttle body coolant bypass problem? | SubasaurusWrex | Factory 2.0L Turbo Powertrain | 4 | 04-27-2006 02:05 PM |
| Throttle body coolant bypass = blocking flow instead of rerouting? | athakur999 | General Community | 7 | 04-13-2006 08:33 PM |
| Throttle body coolant path. | Aus_RS | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 04-26-2004 11:55 PM |
| Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? | Kostamojen | Normally Aspirated with bolt-on Forced Induction Powertrain | 35 | 02-22-2004 09:14 PM |
| Throttle Body coolant line mod | WRX Joe | Factory 2.0L Turbo Powertrain | 41 | 07-14-2002 11:55 AM |
