Alaskan Impreza Club
Old 06-17-2007, 03:52 PM   #1
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
Default Oil Sandwich Plate Adapter...
Just wondering your inputs on the sandwich plate adapters...pros? cons? V.S. oil galley plug location...and what you all are running and why..thinking about getting some gauges in the future and would like to know from some personal experience.
John
asianhulk is offline   Reply With Quote
Old 06-17-2007, 04:01 PM   #2
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
Well, i just installed gauges and the oil galley seems more efficient. thats what i'm running, thanks to Jerry at Conti. We were going to use the oil filter sandwich, but with my car, there's no clearance for it and the sending unit. Oh, well. The oil galley is a more permanent location for the sending unit. It is also much more involved. If you do it yourself, be prepared to be patient and spend alot of time on it to do it right. Jerry can probably tell you more.
MikeyMike is offline   Reply With Quote
Old 06-18-2007, 03:41 PM   #3
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
can you run two sending units from the oil galley plug...like pressure and temp?
Old 06-18-2007, 04:13 PM   #4
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
i doubt there is clearance. Here is a pic of mine and how tight it is with just one sending unit. If thats your case, and you want 2, you'd be better off with the sandwich.
Old 06-18-2007, 05:15 PM   #5
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
if ur gonna get a sandwhich adapter get the greddy one...
SQUAD_907 is offline   Reply With Quote
Old 06-18-2007, 05:58 PM   #6
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
with each type of sandwich, which are more accurate? and by how much off of the galley location?
Old 06-18-2007, 07:27 PM   #7
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
when i ran my defi gauges i had the defi sandwhich adapter...it was like an add on to the oil filter location...only reason i mention brand is because ebay versions have been known to leak and i know a few people that have run the greddy one with no issues...
Old 06-18-2007, 08:49 PM   #8
00Maddog
Member#: 62410
2004 ra'd redrex in
8k w/ STI kit :) DASH
i've seen this done with a small flex hose to relocate the senders where there's more room. i'd still rather tap a main galley then use the filter adaptor.
00Maddog is offline   Reply With Quote
Old 06-18-2007, 09:03 PM   #9
prometheum
Member#: 92003
04 TDI Passat
how do you keep the shavings from drilling and tapping it from going into the engine?
prometheum is offline   Reply With Quote
Old 06-18-2007, 09:08 PM   #10
Longarm
Member#: 132140
'11 WRX Hatch
SSM
You don't drill anything, you remove the oil galley hex plug and insert the oild galley adapter, then screw in the sending unit.......that is how subi does it when they add the gauge pack on the dash
Longarm is offline   Reply With Quote
Old 06-18-2007, 09:29 PM   #11
prometheum
Member#: 92003
04 TDI Passat
really? are those the plugs that are right by the oil filter...i've always wondered what those were for
Old 06-18-2007, 09:37 PM   #12
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
No, see the picture i posted. It's on top of the block.
Old 06-18-2007, 10:28 PM   #13
Sokudo
Member#: 11162
MY98 A4 Avant
run the Greddy adapter....easy install plus options for four outlets...two for senders (temp and pressure) or cooler..
http://www.rallysportdirect.com/stat...ter-p-736.html
Sokudo is offline   Reply With Quote
Old 06-19-2007, 06:18 AM   #14
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
please tell me more
Old 06-19-2007, 07:00 AM   #15
prometheum
Member#: 92003
04 TDI Passat
anyone want to chime in what those 2 plugs are for next to the filter?
Old 06-21-2007, 11:45 PM   #16
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
bump what is more accurate in terms of reading times...galley or sandwich?
Old 06-22-2007, 12:30 AM   #17
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
it doesnt matter. the sending unit is on the oil pressure directly.
Old 06-22-2007, 11:53 PM   #18
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
id get the greddy for ease of install. and its easier to remove sensors if you need to. just go up under the car where the oil filter is and unscrew them. as far as accuracy, oil pressure is pretty straight forward probably better at the bottom of the motor than the top because it take pressure to circulate oil through the filter and temp will be better at the bottom near the oil filter with an adapter because it will always be in the oil. also this way you may not need to remove the intercooler.
sam
shortfuseWRX is offline   Reply With Quote
Old 06-23-2007, 02:56 AM   #19
00Maddog
Member#: 62410
2004 ra'd redrex in
please tell me more
nick at underground did that install, you'd have to ask him for specific hose info etc.
FS: NEW prosport sandwich plate adapter kh15 Accessories & Misc 3 07-02-2009 10:08 PM
FS: New Prosport Oil Sandwich Plate Adapter SPEED6 Interior/Dressup/Audio & Security 3 12-12-2008 05:54 PM
Oil Filter Sandwich Plate Adapter for Sensors div Engine/Power/Exhaust 3 11-04-2008 03:46 AM
FS~*MI-WI*~Panasonic Strada CN-NVD905U DD In dash GPS ATI POD and oil sandwich plate skingfreak MWSOC Private Classifieds 6 04-29-2008 01:14 AM
oil sandwich plate threads? WicK Factory 2.5L Turbo Powertrain 0 05-20-2006 02:06 PM
Message Board Statistics All times are GMT -4. The time now is 09:27 AM.
