Puerto Rico Subaru Impreza Club
Go Back   NASIOC > NASIOC Chapters > Puerto Rico Impreza Club Forum -- PRSIC
Old 12-26-2001, 01:53 PM   #1
javier2971
Member#: 13619
Lightbulb Quien sabe donde se instala el EGT sensor?
Saludos a todos! Soy nuevo en esto de la fiebre y tengo muchas dudas de novato; le agradeceria a quien me pueda decir, y si es posible con una foto, en donde exactamente se instalaria el sensor de calor(EGT) para un reloj "Autometer" en un WRX 2002(Turbo)?
Gracias....Spanky
javier2971 is offline   Reply With Quote
Old 12-26-2001, 02:04 PM   #2
Fantom
Member#: 3166
2002 WRX Wagon
no estoy seguro pero si mal no recuerdo migue
monto uno , comunicate con el 787-251-2850(auto plaza)
ps. de que parte de bayamon eres ???
Fantom is offline   Reply With Quote
Old 12-26-2001, 02:46 PM   #3
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Bueno, segun Shiv de Vishnu Preformance, lo montan a 3 pulgadas del cilindro #1, que es el cilindro mas seco.
Leo
Leonardo is offline   Reply With Quote
Old 12-27-2001, 10:56 AM   #4
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
tiene sentido
Prog is offline   Reply With Quote
Old 12-27-2001, 11:07 AM   #5
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Si te refieres al cylindro mßs cerca del chofer ese tengo entendido es el #4. CorrÝjanme si estoy mal pues pronto estarÚ montando uno.
Gracias,
nativo is offline   Reply With Quote
Old 12-27-2001, 12:24 PM   #6
javier2971
Member#: 13619
Default Can anyone identify on this picture in what Cylinder # is the EGT located?
If you can identify the Cylinder # on this picture that was provided to me taken from underneath the vehicle(WRX 2002), please reply to me soon. All I can say is that it is located on the driver's side.
Old 12-27-2001, 01:53 PM   #7
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Default EGT
That looks as if the sensor is at the collector from the driver's side exhaust. Cyl #4 is the one closest to the driver's feet. If you were to conect it like Leo mentions you would have to get closer to the head or about 1.5in from where the exhaust manifold begins.
Hope you understand.
Efrain
Old 12-29-2001, 07:53 AM   #8
Ch˙SacSVT
First RS in the 12's YEEEEEEEEEHA!
Member#: 129
'03 Corvette Z06
Black as in:180mph Black!
Hola!
El del RS turbo, se lo puse lo mas cercano posible al cyl. #4, que tiende a ser el mas seco y que mas temperatura hace. Mas o menos de 1 a 1.5 pulgadas de la tapa, de esa manera tendras un reading mas certero y los gases no se "mezclaran" en la Y con los del otro cyl. Ademas, despues que ese cyl. en especifico este bien, todos los demas van a estar seguros. El reading no debe ser mas de 1500grados con la pata abajo y full boost.
Jesus
Ex-12sec. 2.5RS-turbo owner
Ch˙SacSVT is offline   Reply With Quote
Wanted: MAF mass air sensor. 02 sensors. EGT sensor timing cover. tscott915 Private 'Wanted' Classifieds 10 10-07-2009 01:26 AM
Se fue el perrito... Kingtut R-S Puerto Rico Impreza Club Forum -- PRSIC 21 12-05-2004 08:46 PM
Modelo nuevo de neon, se chavˇ el STi Stryker Puerto Rico Impreza Club Forum -- PRSIC 2 07-14-2004 12:45 PM
question about bad egt sensor, the egt fix etc Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-12-2004 02:43 PM
otra vez se murio el site! :p Prog Puerto Rico Impreza Club Forum -- PRSIC 11 03-20-2001 07:30 AM
