Old 12-26-2001, 03:56 PM   #1
loeryder
Member#: 3416
2000 Impreza 2.5RS
Silverthorn Metallic
Default Frnt & Rr Diff + X Case Fluid change
Getting ready to do all fluid changes at 25k.
Front and rear Diff - What fluid to use? Mobil1 75W-80 ok?
Any secrets to drainging the front?
X Case - What fluid and how do I drain fill?
Trans sounds simple, anyone know how much fluid and what type to use>?
Model is MY00 2.5RS 5 spd.
Thanks for any help to make this easier.
loeryder is offline   Reply With Quote
Old 12-26-2001, 04:11 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Old 12-27-2001, 12:31 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Yeah, but don't get under the car while supported by a jack like shown in the last picture.
Suggested fluids:
manual transmission: Redline 75W90NS
rear diff: Redline 75W90
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 12-27-2001, 07:22 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I used Valvoline Full Synthetic 75w-90 Gear Oil (which I bought at NAPA) for both tranny and rear diff. I can shift really well in any weather. I made a mistake of using 80w-90. Don't use 80w-90 because you won't be able to shift in the 32 degree or below weather.
Because you have a manual transmission, the transmission includes front and center differentials already. So, changing the transmission fluid takes care of the front and center diffs.
Here is the procedure for manual tranny and rear diff:
http://www.geocities.com/matsut_rpi00
Then click on "Maintenance and Repair".
Make sure you have a breaker bar or impact wrench gun for the rear diff. The drain and filler bolts are very hard to loosen.
tmat3 is offline   Reply With Quote
Old 12-27-2001, 10:36 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Isn't that funny about the rear diff? Torque spec calls for ~32 ft-lbs, but it takes several hundred to break it free. Grr. I recommend jacking the rear way up in the air, breaking the drain/fill free (but not removing), then jacking the front up. Drain the rear with the front way up in the air, then break the front free, drop the car level, plug and fill the rear, and drain the front while level. Plug & fill the front. I removed my Cobb and just used the long pointy bottles to fill, but that was a MAJOR pain, and I spilled gear oil on my exhaust. Now my car stinks. Some day it will go away. After I finished I remembered the siphon hose I bought for such an occasion. Next time...
I used Mobil1 75W-90 for both. Ran me about $35-40.
CosmoTheCat is offline   Reply With Quote
STi Trans. & Diff. Fluid Change i_drank_what Service & Maintenance 82 01-18-2015 08:26 PM
Tranny & diff fluid changes are cake R_W Service & Maintenance 54 04-16-2009 09:47 AM
Problem after 5 MT & Rear Diff Fluid Change jjbehren Newbies & FAQs 27 03-18-2008 02:20 PM
about to do a 6mt tranny and diff fluid change...where to get fluid? OneArmedScissor Texas Impreza Club Forum -- TXIC 9 10-21-2007 01:07 AM
newbie question: Front diff and tranny fluid change ricerocket123 Transmission (AT/MT) & Driveline 5 09-18-2007 03:18 PM
