Old 06-20-2007, 04:34 AM   #1
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Default hybrid 2.5L Short block new setup Q's
I'm looking to build a hybrid motor due to some unfortunate motor problem.
Car is 2005 WRX originally with EJ20
I'm looking to do the following
Bottom end 2.5L short block swap.
deautchwerks 750 cc injector or PE 800 cc injector
Walbro 255 fuel pump
ARC FMIC
and some sort of short ram intake. (HKS SMF Maybe....)
Tuning will be either ecutek or ap street tuner.
The car still be using the stock EJ20 top end stock and 5MT Transmission. (yes i know i know i already did all the reading in regards to weakness of the transmission)
Turbo in consideration
FP Green 8cm - 2.4" inlet internal waste gate
Deadbolt 20G / TD05 8cm
Any suggestion to the setup? am i missing anything?
Kenji815 is offline   Reply With Quote
Old 06-20-2007, 04:40 AM   #2
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
Originally Posted by Kenji815 View Post
Car is 2005 WRX Sti originally with EJ20
so this is not a USDM car? ..
StarDogChampion is offline   Reply With Quote
Old 06-20-2007, 04:45 AM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
sorry fixed.. it's wrx not sti.
My plans is aiming around 300-330 whp.
Reliable daily driving and weekend track car.
quick spool and linear power through the entire power band.
I'm not looking for drag setup with big power.
Looking for autoX , small track, gymkhana setup.
WTB 2.5L short block / long block ibanez24_7 Private 'Wanted' Classifieds 5 02-14-2009 10:14 PM
Hybrid 2.5L short block build Q's Kenji815 Built Motor Discussion 25 08-10-2007 12:42 PM
Interesting tid bit on Sti 2.5L short block IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-26-2003 01:10 PM
2.5l short block with 2.2l heads Tensecgn Normally Aspirated Powertrain 2 02-02-2001 06:06 PM
2.5L short block Tensecgn Normally Aspirated Powertrain 0 11-30-2000 06:14 PM
