Old 08-09-2007, 07:27 PM   #1
Starkiller
Member#: 82741
2007 350Z Silver
Default Silly but serious question
Can an OEM piston w/broken ringland be replaced with an identical(ie replace an A piston with another A piston) good piston, keep the old rings and not have to re-hone the block assuming there was no scoring/damage on cylinder bores?
FSM states only to bore/hone if out-of-roundness, taper or cylinder to piston clearance exceeds tolerance.
Starkiller is offline   Reply With Quote
Old 08-09-2007, 09:20 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I picked up 4 new stock pistons from one of our better known engine builders for $50 shipped. Rings were another 120 ( have to buy a set of 4) . The cylinder was in excellent shape so I just replaced the one that was bad. About 6 months later another one went so I decided it was time to go with better pistons.
I was pushing 400whp which I believe to be the limit of the stock sti pistons in a high compression (9:1) hybrid setup. If your power is near the limit of the pistons I would recommend upgrading so you don't go through what I did.
LiquidForce is offline   Reply With Quote
Old 08-09-2007, 10:13 PM   #3
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
I would not reuse old rings, and from what I have read, you dont need to rehone a cylinder if a good crosshatching pattern is still there.
You should be ok with only replacing the one bad piston....
Also, pistons are designated not only an "a" "b" or "c", but also a "l" or "r" for left and right....
gto7419 is offline   Reply With Quote
Old 08-09-2007, 11:39 PM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
do it, and let us know what happens!
modaddict is offline   Reply With Quote
Old 08-09-2007, 11:49 PM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
While its not obviously recommended, I can see why you would want to do this from a monentary standpoint. And while you may get some unwanted blowyby it should be minimal.
reddevil is offline   Reply With Quote
Morbid but serious question. tess Off-Topic 37 06-22-2007 01:39 PM
Okay it's silly, but i got rocket launcher envy from an earlier post... mshibata Baja Forum 3 05-06-2005 11:52 PM
Silly But.... How do you post PIX's TOMMY B Newbies & FAQs 5 11-20-2001 10:15 PM
Silly but handy trunk hook mod Peaty Interior & Exterior Modification 17 07-23-2001 10:48 PM
