Old 06-20-2007, 04:30 PM   #1
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Default Stock 2.0 ECU OK to run 2.5l hybrid? Cobb says so...
I called Cobb today to see if they had a base map I could run on my hybrid so I could drive it 120 miles to ATL for Topspeed to do the final tune and they said the stock ECU will run it fine so long as I stay out of boost as much as possible. Does this sound right? Anyone have any experience with this? Kinda related to my other post but this is a little more unique.
Acostafan is offline   Reply With Quote
Old 06-20-2007, 09:03 PM   #2
chris_gillespie
Member#: 70263
Sedona Red Pearl
subscribed! I'd also like to know if it's OK to run my V1 AP with Stage 2.5 on a hybrid.
chris_gillespie is offline   Reply With Quote
Old 06-24-2007, 05:06 PM   #3
tundra
Member#: 9290
02 Built 2.5L wrx
I assume the 2.5L sb is the only change from your previous tune?
If so you'll be just fine if you take it easy on the way to the tune. I'd try to stay completely out of boost though, just to be safe.
tundra is offline   Reply With Quote
Old 06-24-2007, 10:59 PM   #4
Acostafan
Member#: 67398
2002 Now with 100%
Got the car running just fine on the 2.0 ECU but we forgot to adjust valve lash so we will have to go back in and do that before it can be tested more thoroughly. FWIW it starts and idles perfectly all day long on the stock 2.0 ECU. Once fixed, we will limp it 120 miles to ATL to let Topspeed do the final tune.
Old 06-26-2007, 12:42 AM   #5
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
I'm still using my 05 wrx ecu, aside from boost control, nothing really HAD to be changed, the ecu can cope with it.
05redrex is offline   Reply With Quote
Old 06-26-2007, 01:26 AM   #6
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
i have my 2.0L 02 ecu running a sti longblock........basic setup is sti complete longblock, wrx intake and exhaust manifolds, pretty much everything else wrx,xceptfor a vf39
mcu81 is offline   Reply With Quote
Old 06-27-2007, 05:10 PM   #7
Acostafan
Member#: 67398
2002 Now with 100%
I hope you got a tune....
Old 06-28-2007, 11:33 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
use the valet map it limits you to 3k and a zero boost target
Old 06-28-2007, 05:45 PM   #9
Acostafan
Member#: 67398
2002 Now with 100%
I thought about that but don't turbo engines need to see SOME boost for everything to seat right? That's the map I really need....it would need to make sure my A/F's are OK so we don't have det issues as well.
2.0 to 2.5L with blown 2.0 ecu????? AUTO DjKlown UTEC 1 11-20-2008 07:58 PM
Installed TBE; Tuner Says OK To Run AP Stage 1 Map sfflyfish AccessPort 1 09-24-2008 01:15 PM
stupid question, ok to run 2 diff sets of tires? Ghost Rider Tire & Wheel 9 10-13-2006 03:27 PM
ok to run helix top mount ic with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-09-2005 07:07 PM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 11:40 AM
