Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 06-21-2007, 03:50 PM   #1
synapseengineering
Member#: 111393
Default Synchronic BOV
There have been some threads inquiring about this design
and I would like to answer any questions/concerns that you have regarding this product and how it works. I can't post links to the user manual or vids, so if you would like to see these PM me and I will send you the links.
Synchronic was designed to be a fast acting BOV that eliminates compressor surge and has these features:
*Retails for $219 (contact your NASIOC sponsor retailer)
*Atmospheric or recirculated discharge
*Retail kit includes 1.25" recirc fitting and stainless weld-on pipe flange
*No need to adjust or figure out which spring to use for your application
*Interchangeable mounting flanges so that you don't have to refabricate when switching from another BOV
-HKS SSQ/TypeII mounting flange
-Greddy Type S/R, HKS racing mounting flange
-Aluminum Weld-on flange
-Tial 50mm mounting flange (available in 3 weeks)
-1" inlet & discharge hose-end fittings (available in 3 weeks)
*Anti-stall valve is now available for MAF cars with an atmospheric dump
*An overboost protection circuit is in development that is already built into the BOV
synapseengineering is offline   Reply With Quote
Old 06-22-2007, 01:23 AM   #2
RallyBlue
Member Sales Rating: (5)
Member#: 69323
2004 WRX
82 BRAT
Here are some videos explaining this breakethrough in BOV/BPV design.
Synapse BOV vs Tial http://videos.streetfire.net/video/4...ee0182efa3.htm
Synapse BOV vs HKS SSQV http://videos.streetfire.net/video/6...3f0150f005.htm
He also has a EWG that works on the same princepal
http://videos.streetfire.net/video/7...e900493336.htm
http://www.youtube.com/watch?v=LStlqe64m4M
And the SEMA 2006 Streetfire interview
http://videos.streetfire.net/video/b...7800261cd3.htm
I am currently running a prototype synapse 40mm EWG on my 30R WRX
I can say that against the Tial 38mm that I was running this WG is Very smooth. The power delivery is more linear and does not choke when at the top of the RPM band.
These products are very well designed and would highly recomend them to anyone going EWG or to replace your current WG with these.
RallyBlue is offline   Reply With Quote
Old 06-28-2007, 02:40 PM   #3
engineerx
Member Sales Rating: (32)
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Any updates?
Are the EWG's available yet? >> which vendors?
engineerx is offline   Reply With Quote
Old 06-28-2007, 02:53 PM   #4
synapseengineering
Member#: 111393
EWG's are in stock now. The only thing I don't know is which of my distributors are NASIOC sponsors, so for the retailers out there I'll post the wholesalers that the NASIOC sponsors probably buy from:
Pro-Motion Distributing
Motovicity Distributing
or you can check out our distributor page
More Hot Topics on NASIOC...
Old 06-28-2007, 04:07 PM   #5
Andrew
Member Sales Rating: (3)
Member#: 1170
2005 STi
What does an anti-stall valve mean?
Andrew is offline   Reply With Quote
Old 06-28-2007, 07:16 PM   #6
Andrew
Member#: 1170
2005 STi
I just read your manual: http://www.synapseengineering.com/ar...bov_manual.pdf
it sounds like the valve allows the BOV to close during vacuum; therefore, not forcing the car to run rich or other problems which are generally associated with an atomospheric bov with a car where the maf is before the turbo.
am i right?
Old 06-28-2007, 10:06 PM   #7
bzbuzz
Member Sales Rating: (9)
Member#: 116052
06 wrx ltd
vf34
so this bov is safe for WRX for sure? and we can enjoy the sound w/o no problem at all? I am very curious to see actual reviews from us...anybody?
bzbuzz is offline   Reply With Quote
Old 06-29-2007, 03:35 AM   #8
synapseengineering
Member#: 111393
I designed Synchronic BOV to be fast reacting. Basically, to follow exactly the events in the intake manifold. Ideally, I would like to see end-users re-routing the discharge after the air flow meter. When this is done you may actually see improved gas mileage as well since this is feedback that we have received.
However, I know that there are many out there that want that atmospheric dump. And so, the Anti-Stall valve was developed so that you could dump to atmo and still be able to idle without the car running lean at idle by sucking in unmetered air after the MAF (correct Andrew). However, whenever you dump metered air out to atmo you have fuel in the system without the amount of air that was intended for it, so you may still get richness between gears.
Old 06-29-2007, 06:48 PM   #9
Andrew
Member#: 1170
2005 STi
I don't understand how the anti-stall works. Could you explain it to me? Why would it work when the car idles but not when you shift?
NM I think I get it. When you shift, you let out the boost pressure, but at idle it closes... So it closes when you shift too, but the point is, is that you are letting out metered air and nothing is compensating for that.
edit:
After thinking about it, wouldn't the richness come from sucking air in after the maf? Instead of letting the air out?
Old 07-02-2007, 04:51 AM   #10
dingobite
Member Sales Rating: (23)
Member#: 82391
08 OBP Sti
stg2.... 328awhp, 370tq
Any updates yet on the BOV when it will be availible for subarus ?
dingobite is offline   Reply With Quote
Old 07-03-2007, 01:16 AM   #11
djerickd
Member Sales Rating: (34)
Member#: 3782
02 Old Skool WRX
WFC #040 Still Flossin!!!
Awesome deisgn! PM'd u
djerickd is online now   Reply With Quote
Old 07-05-2007, 10:30 AM   #12
arkedias
Member#: 153090
good deal !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
arkedias is offline   Reply With Quote
Old 07-08-2007, 04:01 PM   #13
synapseengineering
Member#: 111393
Finally a vid on a Subaru, the slight flutter you hear is from the anti-stall valve because this user wanted it dumped to atmosphere, it is non-existent when recirculated.
http://www.youtube.com/watch?v=NQAcVgKPXG4
Old 07-08-2007, 09:29 PM   #14
djerickd
Member#: 3782
02 Old Skool WRX
wow it's very effective!!
Old 07-08-2007, 09:59 PM   #15
ERIKBROCKHOFF
Member#: 142599
#2 FTW if the car isn't running rich in between shifts.
ERIKBROCKHOFF is offline   Reply With Quote
Old 07-08-2007, 10:01 PM   #16
ERIKBROCKHOFF
Member#: 142599
Or put holes in the hood LOL
Old 07-08-2007, 11:39 PM   #17
bzbuzz
Member#: 116052
06 wrx ltd
vf34
can we hear it w/ recirculated one?
Old 07-09-2007, 12:59 AM   #18
flwrx
Member Sales Rating: (25)
Member#: 35944
'03 WRX
'76 Fleetwood Brougham
does it require lubricating or cleaning?
flwrx is offline   Reply With Quote
Old 07-09-2007, 03:42 AM   #19
synapseengineering
Member#: 111393
flwrx, the SB001 comes pre-lubricated from the factory. The lubricant is proprietary and will not evaporate over time and should not require further application. Also, the Synchronic geometry allows the design not to have metal to metal contact, so the only potential wear points over time are the o-rings and our formulated lubricant should eliminate that possibility.
BZ-It is very hard to hear recirculated.
BTW, Anytime you dump metered air to atmosphere, you will run rich between shifts. Although some BOVs make the effect worse than with others. It is all about fast actuation, we're talking milliseconds. The faster the valve shuts between gears, the less richness you get.
Old 07-09-2007, 01:52 PM   #20
dingobite
Member#: 82391
08 OBP Sti
My forge bpv sounds every much like the tial including the whiny little ping sounds during boost, during the time underboosting and dropping out of boost at WOT i can no longer stand the sound.
You bov sounds much nicer even venting like a bov.
Old 07-10-2007, 04:14 AM   #21
synapseengineering
Member#: 111393
This is something to look into. I haven't heard of this being prevalent with the Forge units. Thanks for the heads up.
Old 07-10-2007, 09:15 AM   #22
dingobite
Member#: 82391
08 OBP Sti
Im not sure if i just have a defective unit or not, theres a few things that could be wrong i will be taking it with me for my tune next week.
I think it may be my tune thats making it sound this way im not 100% possitive but i think that what the problem is.
sorry to /thread jack.
EDITED i think i know the problem.
Old 07-18-2007, 10:37 PM   #23
Fauj
Member Sales Rating: (2)
Member#: 142777
2007 wrx limited
crystal grey
will the bov come with a flange that fits the stock intercooler? And is the resirc piece included?
who is the nasioc vendor?
Fauj is offline   Reply With Quote
Old 07-19-2007, 04:05 AM   #24
synapseengineering
Member#: 111393
The BOV kits are currently going to be the universal kit and you would then purchase the flange kit for your given model. This may actually be a good thing for most. Once you upgrade your intercooler piping you will already have the weld-on flange and recirculation fitting.
Old 07-19-2007, 01:12 PM   #25
Fauj
Member#: 142777
2007 wrx limited
crystal grey
r u selling the flange kit for the stock intercooler i guess is my question then, is it avaliable?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:09 PM.
