#1 |
Member Sales Rating: (1)
Member#: 284792
RMIC
Vehicle:2011 STI Plasma Blue Pearl |
Edit: Clutch line installed. Review on my third post vvv
I'm in the market for a coated, braided stainless steel clutch line for my STI. The two that I've come across are the Goodridge clutch line and the Mach V Motorsports clutch line. Will I be compromising build quality or reliability going with one or the other? All in all, the Goodridge is a few bucks cheaper. I may end up flipping a coin to make my decision, unless someone has a solid reason why one should be bought over the other. Thanks y'all! DMD
#2 |
Member Sales Rating: (2)
Member#: 243992
Vehicle:2006 WRX TR WRB |
I went with goodridge just because it was the same as my brake lines
Goodridge lines are dot approved (or at least meet dot specs) |
#3 |
Member Sales Rating: (6)
Member#: 113674
Vehicle:2006 WRX ltd, 18g'd WRB, 355whp/365wtq |
i've got the Mach V clutch line (and their matching brake lines). no issues so far. been on for over a year now. definitely firmed up the clutch feel. easy to install and no debris gets into the braiding thanks to the red sheathing around it. quality is very good. install was relatively painless (once the TMIC is out of the way). you'll probably be fine with either, but im just +1 for Mach V.
#4 |
Member#: 284792
RMIC
Thanks guys. I already flipped the coin and went with the Goodridge line. I found one for ten bucks less than the MachV line. I appreciate the replies.
#6 | |
Member#: 284792
RMIC
The clutch pedal feels amazing! Much more even pedal pressure throughout the range of motion. No more squishy clutch feel. It's not any harder to push in, but it definitely has a more solid feel, especially when pushing the clutch hard and fast. I would recommend to anyone wanting to remove some slop from their clutch pedal. Here is my detailed install writeup, hopefully it helps any of you all wanting to get a clutch line too: http://forums.nasioc.com/forums/show....php?t=2419445 Last edited by RoadKillDMD; 04-25-2013 at 09:46 AM. |
