Old 06-22-2007, 01:43 AM   #1
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
02 WRX PSM Stage 3+ SOLD!
Question JDM v7 STi TMIC Install on 02-03
I know this is in Unibomber's TMIC FAQ, but it doesn't answer to this particular question nor has 3 days of searching and asking various people via PMs. I bought a JDM STi TMIC v7. It has nothing but the TMIC, meaning no y-pipe or any pipes for that matter throttle body, etc. I'm having a real tough time getting a straight/common answer. What is needed for an install on the 02-03 models? I've heard the following answers:
#1 everything OEM is fine and bolts right up, y-pipe, hoses, etc
#2 everything but throttle body hose, bolts right up, y-pipe, etc; so you must buy the OEM STi USDM Throttle Body Hose
#3 you must get the whole Perrin or Gruppe-S kit and TB hose
Can we agree on any of these for the 02-03 MODELS<----
Remember this pertains to 02-03s only, because I've found PLENTY threads on the later years but from what I understand the v7 fits this car better/differently than any newer years.
Thanks HUGE in advance for answering 3 days of looking myself.
#1!!! FTW is the correct answer. I did it and will post pics below as proof.
My issues were the following:
#1 Getting the y-pipe and the TB hose BOTH in position to forcefully push on.
#2 Keeping them BOTH on while forcefully pushing hoses onto the turbo and TB.
#3 Although I'm told hardly noticeable, after finished the TMIC sits crooked (left is slightly higher than right)because...
#4 The right side attaches to the bracket and I haven't found a way to attach the left or it would probably fit even. But I don't see how it's possible the way the pipe/hose leaves its position when in the proper fitment.
ThePunisherGT is offline   Reply With Quote
Old 06-22-2007, 06:16 PM   #2
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
Finished project
Couple pics of throttle body OEM hose fitting (y-pipe also in background in 1st pic)
OEM Y-Pipe Fitting
A/C Line NOT touching, WITHOUT bending anything
Old 06-22-2007, 08:16 PM   #3
Vahnatai
Member#: 25027
Bolts right up. Dunno it the stock y-pipe will work though
Vahnatai is offline   Reply With Quote
Old 06-22-2007, 09:15 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Good question. I'm 98% sure the OEM throttle body hose will fit as I'm using my OEM one with my Ver. 7 right now. As to the Y pipe...I'm like 81% sure the OEM one or any aftermarket one will fit. If nothing else, try it out....swapping out intercoolers is not hard, so do a test fit and that will give you your answers.
Old 06-22-2007, 09:26 PM   #5
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
Let us know what you find out so that future search results will turn up the correct answer for other who want to know the same thing.
Carlos
Carlito2002WGN is offline   Reply With Quote
Old 06-22-2007, 09:46 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
when I installed it into my friend's car we reuesed pretty much everything. USDM STi TMIC is not a simple bolt on though...
Old 06-22-2007, 10:23 PM   #7
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
Yea I read your FAQ and the v7 link on it like 15 times and, like i said, i did 3 days of searching, found nothing. So i appreciate the post here from you. I will follow through back here so that future people will know the answer.
Vahnatai: I did know the bolts match up perfectly that info is unanimous and easily found, but thank you.
txl146: Thanks for the tip, because that is my plan for now. Also a well known fact about the USDM, but again thank you for your time, reading my post, and posting.
Old 06-23-2007, 01:26 AM   #8
richy_21
Member#: 58670
2005 got muuuuu?
^ get back to work....
richy_21 is offline   Reply With Quote
Old 07-30-2007, 01:27 AM   #9
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
Updated!!
Old 07-30-2007, 03:07 AM   #10
Suby*Doo
Member#: 148732
OT dates super
models. Deal with it
hahah 81%...nice
Suby*Doo is offline   Reply With Quote
Old 12-12-2007, 10:47 PM   #11
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
Cool
People are looking for this info it seems, from what I'm hearing. Any chance of it getting moved to the proper section and/or maybe a link in Unibomber's awesome Manifesto about TMIC's? Maybe like the "How do I install a TMIC?" section?
Old 12-13-2007, 01:00 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
please measure and post the IC core size----the top opening, inside measurements
Old 12-13-2007, 08:07 AM   #13
ThePunisherGT
Member#: 121305
2004 WRX WRB Sedan
Question
Well the top measurements a no brainer but how do I go about measuring the inside?
Old 02-09-2016, 02:04 PM   #14
psshhhaa
Member#: 357158
2005 Saab 9-2X VF48
Deep Blue
I'm having the same problem right now trying to get everything to fit. Do I just reuse all the stock wrx IC hoses with the V7 TMIC? Do I use the wrx ypipe or V7 TMIC ypipe?
psshhhaa is offline   Reply With Quote
FS in CT: JDM V7 STI splitter and USDM 02/03 WRX hoodscoop and splitter (MBP) gling Exterior/Styling 14 07-18-2007 11:26 AM
FS Socal: JDM V7 STI Fog Covers PSM 02-03 Bug Eye ComTekAuto Exterior/Styling 2 03-14-2007 03:16 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
