06-22-2007, 08:29 PM | #1 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
Is my AVCS on?
Phil helped me with a wiring schematic and I think it lives! I hear 2 clicks from the solenoids when I turn the key on. Phil had said that there was a way through pwm10 to cycle the solenoids to make sure it is on. I emailed him, but it's Friday night and I assume he has a life. I'd like to get this buttoned up tonight if I'm assured that it is working. I'll be checking back if any of you are working on cars and Nasiocing on a Friday night
06-23-2007, 12:07 AM | #2 |
Member#: 23258
Vehicle:2005 STi White |
Too bad nasioc doesn't have the 'big "L" on the forehead' smiley....
06-25-2007, 03:10 PM | #3 |
Member#: 30367
South East
bump.
06-25-2007, 03:30 PM | #4 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
06-25-2007, 07:23 PM | #5 | |
Member#: 30367
South East
Well it seems that AVCS in on!!! On the passenger side only Bad solenoid I guess. Probably fried when I hooked it up wrong before. Now, where the hell am I gonna get an AVCS solenoid? |
06-25-2007, 08:45 PM | #6 |
Member#: 21893
SWIC
Vehicle:2002 WRX w/STi swap PSM |
Part number 10921AA020 $78.64 from
https://www.subarugenuineparts.com/oe_parts_cat.html (I had to buy one) |
06-25-2007, 08:52 PM | #7 | |
Member#: 30367
South East
06-25-2007, 08:57 PM | #8 |
Member#: 21893
SWIC
Undo the top 10mm bolt and slide it out (toward the rear of the engine). It is about a 2 inch inserted piece. I replaced it on a USDM Sti head so I am not sure if it will fit a EJ207.
06-25-2007, 09:03 PM | #9 |
Member#: 30367
South East
06-25-2007, 09:24 PM | #10 |
Member#: 30367
South East
Good news. The solenoid is good. Bad news, I don't know what's wrong. I plugged the drivers solenoid into the passenger plug and it was clickin' it's ass off. Plugged it back into the driver's side and just get a dull vibration (barely audible). Hmmmm
06-26-2007, 09:38 AM | #11 |
Member#: 54918
I'm not sure what value you used in PWM Map 10 but try setting it at different values to make sure it's a bad solenoid and not an issue with the frequency.
Thanks, Phil www.elementtuning.com |
06-26-2007, 10:05 AM | #12 | |
Member#: 30367
South East
06-26-2007, 02:40 PM | #13 |
Member#: 54918
It sounds like you have a bad solenoid. They should both work identically. They are controlled by the same PWM Map but two different outputs from the Hydra. This would be outputs 1 and 3 for the WRX and should both be assigned to PWM Map 10.
06-26-2007, 04:13 PM | #14 | |
Member#: 30367
South East
AVCS or bust!!!! |
06-27-2007, 01:32 AM | #15 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
06-27-2007, 10:59 AM | #16 | |
Member#: 54918
06-27-2007, 11:58 AM | #17 | |
Member#: 30367
South East
Thanks Phil. With all my wiring, re-wiring, poking and prodding I think I have totally roasted the AVCS signal from the Hydra. Good news is the car still runs and the Hydra still loads maps. Bad news is, I now get no clicking or humming from either side and no voltage on the AVCS wires. I emailed HYDRAEMS to see about sending it in. Hopefully the Hydra can be repaired. I should not be allowed to work on cars |
07-02-2007, 10:11 AM | #18 | |
Member#: 54918
What The Hell Is My Offset On These Rims? | bullysonwrx | Newbies & FAQs | 27 | 06-30-2009 11:18 PM |
Is my Avcs not working properly ? | Sammidavis | Engine Management & Tuning | 6 | 06-26-2009 10:31 AM |
is my tranny on the way out? | BriBoogie | Transmission (AT/MT) & Driveline | 6 | 04-17-2007 09:31 PM |
Bad Detonation Still- Is my engine on its way out? | JeffrWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 30 | 03-04-2006 01:29 PM |
why is my cel on? | Rubasu | Service & Maintenance | 7 | 01-03-2003 03:10 PM |
