Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 12-27-2001, 11:32 PM   #1
GusS
Member#: 12879
1992 Legacy L Wagon
5spd, AWD, White
Default Trouble codes 22 & 42 on a BF Legacy
Hi,
I'm getting the following trouble codes:
22: Knock sensor - Abnormal voltage produced in knock sensor monitor circuit. Sets in regular fuel map and retards ignition timing.
42: Idle switch - Abnormal voltage input entered from idle switch. Judges OFF operation.
Around how much are the parts needed and can this job be performed by a novice?
GusS is offline   Reply With Quote
Old 12-28-2001, 12:38 AM   #2
iceman
Member#: 1546
95 Legacy L
I'm a novice too, but you can try a ECU reset. I don't think it will help, but you can't lose anything. However it sounds like you need a new Knock sensor.
Hope this helps,
Ice
iceman is offline   Reply With Quote
Old 12-28-2001, 07:20 AM   #3
GusS
Member#: 12879
1992 Legacy L Wagon
5spd, AWD, White
Iceman these are new.. I reset it about 2 weeks ago when I had a canister purge solenoid code. I replaced the solenoid and now I have this.
Old 12-28-2001, 02:56 PM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default hmmm
The idle sensor I have no experiencewith but the knock sensor I have replaced.
It is a relatively easy replacement with an extension and a u-joint on a socket wrench. Its beneath the intake manifold on top off the block almost directly under the throttle body.
Try this before you replace it: Remove the knock sensor and clean the base of it a well as the mating surface on the block with steel wool. This will sometimes remedy the problem.
Otherwise it needs to be replaced. I had to go to the dealer for the part (appr. $40.) HTH
subysouth is offline   Reply With Quote
P0519 trouble code on 2003 WRX mick_the_ginge Engine Management & Tuning 13 09-02-2010 07:17 PM
1999 Legacy Limited Outback Wagon PO440 trouble code jrduck1 Newbies & FAQs 2 11-15-2009 12:41 AM
BPM TB & Many Trouble Codes! mossie4 Newbies & FAQs 6 07-07-2005 05:47 PM
For SALE: UNIQUE & FAST, ON/OFF Road Legacy Wagon sshick Private 'For Sale' Classifieds 1 03-24-2004 10:30 AM
Brullen Sound Clip & Pics on a '98 Legacy L w/ 4EAT GTBGUY Legacy Forum 12 08-22-2001 01:46 PM
