Old 06-25-2007, 12:43 AM   #1
lgt2000
Member#: 140073
2005 LGT
Red
Default Going from NA Legacy Water Pump to WRX Water Pump
I am planning on using stock WRX exhaust manifold so I have found out that I need to change my water pump. I am going to go ahead and do my timing belt and use a WRX water pump instead of the NA Legacy one. Is there any extra accessories other than the water pump gasket that I will need with this water pump and can people that have done this swap give me any tips. Thanks
lgt2000 is offline   Reply With Quote
Old 06-25-2007, 01:22 AM   #2
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
It's a direct swap. You'll need a turbo thermostat housing. More info here...
http://www.uniquemotorsports.com/Jon/index.htm
Harenil is offline   Reply With Quote
Old 06-25-2007, 09:38 AM   #3
lgt2000
Member#: 140073
2005 LGT
Red
thanks, just what I was looking for, does anybody have a part number for the thermostat housing
STi oil pump vs. WRX oil pump hypoxvi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-04-2009 01:44 PM
Converting power steering pump to crankcase vacuum pump? bugeyes Built Motor Discussion 8 04-12-2008 11:38 PM
Ever installed an in-line pump to boost water pressure? Reciprocity Off-Topic 6 10-16-2006 02:53 PM
STi fuel pump vs. WRX fuel pump WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-02-2005 08:05 PM
Legacy 2.5 to WRX 2.0 Swap jacksonww Legacy Forum 7 09-08-2003 03:20 PM
