Old 06-25-2007, 02:26 AM   #1
pondomoto
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
Question Spring choice for Koni Inserts on 02 RS
i have an 02 rs with 24mm rear bar and 22mm front bar and wanted to upgrade to Koni inserts. While doing this, im going to upgrade the springs as well. My question is: what springs work well with these inserts for a daily driver? I dont plan on racing much but i do want less body roll for the twisty roads here in Nor Cal Also, what is a good top hat to use with these?
pondomoto is offline   Reply With Quote
Old 06-25-2007, 06:56 AM   #2
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
'04+ USDM STi sedan spring (should only be $50 for some takeoffs here on NASIOC) with '04+ tophats. Get the 04+ Koni inserts for that combo.
Do you care about how low the car is going to be? This setup would lower your car only slightly.
Jard is offline   Reply With Quote
Old 06-25-2007, 10:09 AM   #3
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Also, you could go with a lot stiffer spring with those struts and be okay, it just depends how much ride quality you want to give up...
Midwest: 2006 Wrx sedan OEM springs and shocks 60K Use the shocks for Koni Inserts! COBOMO Suspension/Brakes/Handling 3 05-12-2010 11:36 PM
fs: Stock 02 WRX struts. 75 for all 4. Great for koni inserts!!! IIdiceII Tri-State Area Private Classifieds 2 02-20-2008 02:05 AM
Which springs with Koni inserts on Sti? meajas12 Brakes, Steering & Suspension 6 07-12-2006 12:43 AM
Want my used '98 RS struts for koni inserts? FREE... GreenRS New England Impreza Club Forum -- NESIC 1 11-16-2005 08:02 PM
List of Parts for Koni Inserts, Prodrive Springs, and STi Upper Mount Install downeyer Brakes, Steering & Suspension 5 07-14-2003 08:13 PM
