Old 06-25-2007, 09:13 AM   #1
15secWRX
Member#: 52088
07 limited
URBAN GRAY
Default wrx brakes and H6 rear brakes to 2000 RS-What do I need?
I plan on doing a swap with wrx brakes and H6 rear brakes on my 2000 RS, what parts would I need from trh WRX? Would upgrading the front calipers be worth it? Or should I just get the wrx front caliper brackets? And if I get the H6 caliper bracket and rotor, what else would I need from the wrx rear brake assembly?
15secWRX is offline   Reply With Quote
Old 06-25-2007, 09:54 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
front calipers are the same 02 to mid 03
you need
wrx rotors
wrx caliper brackets
h6 rotors
h6 caliper brackets
you don't even need to remove the brake lines
Old 06-25-2007, 10:29 AM   #3
15secWRX
Member#: 52088
07 limited
URBAN GRAY
cool thanks, do you think its worth it to swap over the calipers? or is there not much of a difference in size?
Old 06-25-2007, 10:32 AM   #4
Siper2
Member#: 1134
2007 BMW 328xi wagon
No, they're exactly the same.
The above parts listing is correct. However you'll have to bend back or tear off the rear rotor dust shield, as the new rotor won't clear it. I just used a hammer and chisel to break the spot welds.
=S2=
Siper2 is offline   Reply With Quote
NNJ: WRX 02 - 06 H6 Rear brake upgrade Chandy69 Tri-State Area Private Classifieds 12 09-26-2007 01:21 PM
FS: Subaru 4-pots and H6 rear brakes RayQuon Canada Region Private Classifieds 3 10-20-2006 01:34 AM
WRX/STI Radiator in 2000 RS, what do I need amorton Normally Aspirated Powertrain 1 07-15-2005 06:39 PM
About to buy a 2000 2.5 rs, what do i need to look for? imprzya Normally Aspirated Powertrain 14 06-01-2005 08:01 PM
03 WRX Brakes into 02 RS, What do I need? BlackfeetVI Subaru Conversions 2 08-28-2003 03:11 PM
