Old 12-27-2001, 07:49 PM   #1
BMW Man in 2.5RS
Member#: 4162
2001 Impreza 2.5RS
Default One Fo Light Out
OK when i got my car both fogs worked and i decided to replace them with after market one's. The passenger side one burned oput after about a week. I went t put the stock bulbs back in and only the driver side one stll worked. I bought some new bulbs and have tried bulbs that i know work in the passenger side light but It still will not work. The fuse in the console is not broken. I was wondering what the chances were that the aftermaket bulbs fried my one wiring harness and not he other one. I did run the aftermarket bulbs on the drivers side for months afterwards and it still worked. Is there a seperate fuse for each fog. How can i tell if the wiring harness is fried. PLease reply...Joe
BMW Man in 2.5RS is offline   Reply With Quote
Old 12-27-2001, 11:14 PM   #2
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Were the wattages higher than stock? Maybe you can list the aftermarket light you bought and see if anyone else had similar problems. Have you checked to see if your getting any current to the plug with a voltmeter? just a start Good luck
Poppa smurf is offline   Reply With Quote
Old 12-28-2001, 12:53 AM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Pull your lamps off and swap them, test, then swap back and test again. That'll tell you if the problem is in the lamp itself or upstream on the wire. I assume you don't have an electrical test light or voltmeter. You might consider picking one up.
CosmoTheCat is offline   Reply With Quote
Dash lights and brake lights out RCPC Electrical & Lighting 1 03-12-2009 12:02 AM
climate ctrl. lights and switch lights out czo79 Legacy Forum 14 06-05-2006 04:27 PM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
Help! I blew out one fog light on the way to the Doo Wops jonnysubby North West Impreza Club Forum -- NWIC 11 03-07-2005 07:58 PM
Fog light switch light out...can I replace it? JasonRan General Forum Archive 9 07-21-2000 11:11 PM
