Old 06-25-2007, 11:28 AM   #1
jamosthemagician
Member#: 152297
2002 2002 WRX
Exclamation Oil drain plug leaking
Well, my grease monkeys screwed me in more ways than one. My oil drain plug is cross threaded and my car is leaking oil. Has anyone had this problem? What can I expect? I hope the plug can be replaced without significant issues with my oil pan [$$$].
jamosthemagician is offline   Reply With Quote
Old 06-25-2007, 11:35 AM   #2
racingfish
Member#: 60976
1969 LGT
FATURBO
try to have it retapped. are you sure its cross threaded or did you reuse the crush washer?
racingfish is offline   Reply With Quote
Old 06-25-2007, 01:14 PM   #3
ksintener
Member#: 152347
Good Very Nice
ksintener is offline   Reply With Quote
Old 06-25-2007, 01:33 PM   #4
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
If it's cross threaded then go back and show them. Demand they fix it. After that, change your own oil so you don't have to rely on idiots to do it.
MannyMohawk#5 is offline   Reply With Quote
Old 06-25-2007, 09:26 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally Posted by MannyMohawk#5 View Post
.... Demand they fix it. ....
Since this may invite worse damage, let's change it to "Demand they pay for fixing it."
I'd certainly want an experienced Subaru mechanic or dealership service dept to look at it for an estimate before trying something (like re-tapping) that might dump metal shards into the oil system.
Old 06-25-2007, 09:50 PM   #6
IEcaliWRX
Member#: 122087
2004 Stg2. WRX Wagon
Its pretty big bolt. Hard to find a plug to fit it. I ended up getting a new oil pan from genuine suby for like 60 bucks. Its a pita to do yourself.
IEcaliWRX is offline   Reply With Quote
Old 06-26-2007, 02:06 PM   #7
racingfish
Member#: 60976
1969 LGT
FATURBO
a lift would make the job a whole lot easier.
Old 03-05-2008, 10:45 PM   #8
McLovin07
Member#: 159235
07 WRX TR,
CGM
Are you sure its crossed threaded. If they forget to put a new crush ring on the drain plug, there will be a slight oil leak.
McLovin07 is offline   Reply With Quote
Old 03-06-2008, 12:48 AM   #9
wirolla
Member#: 109725
2001 GM6
SRP
McLovin, you fail.
wirolla is offline   Reply With Quote
Old 03-06-2008, 12:53 AM   #10
McLovin07
Member#: 159235
07 WRX TR,
CGM
Yeah my bad, I didn't realize the date it was posted
Oil drain plug leaking Knight_Fall Newbies & FAQs 22 10-15-2009 03:58 PM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Where to get an Oil Drain plug for oil temp sensor ? (HKS CAMP) Extraze Factory 2.5L Turbo Powertrain 3 08-27-2004 03:35 PM
Oil Drain plug fell off of my Nissan 200SX after dealer oil change plunk10 Mid Atlantic Impreza Club -- MAIC 8 08-05-2003 12:48 PM
DIY Oil Change: How do you remove oil drain plug? RSarte Newbies & FAQs 14 07-10-2001 12:11 AM
Message Board Statistics All times are GMT -4. The time now is 09:20 PM.
