Old 06-25-2007, 01:44 PM   #1
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Default Hard to fuel up after fuel pump upgrade ! Any ideas ?
I had a Walbro fuel pump installed in my 06 STi last fall. Ever since then I have had to pump fuel at a slow rate. It's worse when it's hot out. Could I have a vent line pinched ? Has anyone ever seen this happen before ?
Thanks for any ideas ! Okey
I just realized this is in the 2.0 forum instead of the 2.5 forum ! Please move it for me. Thanks
Okeyd57 is offline   Reply With Quote
Old 06-25-2007, 08:45 PM   #2
Okeyd57
Member#: 113271
2006 STi
Bump. Anybody ?
Old 06-26-2007, 10:42 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what do you mean you have to pump at a slow rate?
what happens if you pump at a fast rate?
Old 06-26-2007, 12:47 PM   #4
marcymarc
Member#: 112861
2013 STi sedan
2nd that does it overflow?
marcymarc is offline   Reply With Quote
Old 06-26-2007, 12:55 PM   #5
Okeyd57
Member#: 113271
2006 STi
I mean I have to pump the fuel slowly. If I try to pump it fast it cuts off. It will not take fuel from the pump with the lever squeezed all the way ! I have to barely squeeze the lever to keep it from cutting off. Is that any plainer ?
Old 06-26-2007, 01:03 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what happens if you lift the nozzle partially out of the filler neck before triggering? don't pull it out past the trapdoor in the filler, though.
Old 06-26-2007, 01:25 PM   #7
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
everynow and then i get that.
99subi is offline   Reply With Quote
Old 06-26-2007, 01:34 PM   #8
marcymarc
Member#: 112861
2013 STi sedan
that happens to me ALOT.. but i notice its only at 1 of the pumps i use.
i think its the gas station's actual pump, and not your car.
or does it do this at EVERY pump you go to?
Old 06-26-2007, 01:43 PM   #9
jargon
Member#: 107150
It's the gas station's pump and has nothing to do with your car. Certain gas pumps are set up to cut off if you don't use quite a bit of downforce on the nozzle. Yes, it's retarded. Some stations don't have it; these are the ones that I like to frequent. Filling up a motorcycle tank is a b*tch using some new style pumps.
jargon is offline   Reply With Quote
Old 06-26-2007, 03:56 PM   #10
Okeyd57
Member#: 113271
2006 STi
Mine does it at EVERY pump I use. I never had any problem so to speak of, before the fuel pump upgrade. Isn't there a vent somewhere that allows the air to escape while fueling ? I'm convinced that's where my problem lies, but I need to know how to repair it.
It's hard to believe I'm the only person that this ever happened to when changing fuel pumps, but then again, that would be just my luck ! It's just a matter of the right person reading this to help me out ! Thanks again, Okey
Old 06-26-2007, 04:43 PM   #11
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
the fuel pump its self is not to blame. go in your trunk and remove the fuel pump cover to see if anything is pinched if you want, but that should not affect filling up the tank. might just be coincidence..
StarDogChampion is offline   Reply With Quote
fuel starvation after new pump install jlam86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 06-07-2008 06:18 AM
anyone in Marlyand area know how to wire up a fuel pump controller? simprezl25 Mid Atlantic Impreza Club -- MAIC 8 06-25-2006 05:15 PM
Very strange noise after shutting car off... any ideas? OttawaSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-14-2005 09:16 PM
car smokes after driving a while, any ideas? verc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-02-2004 12:41 PM
Turbo upgrading.. any ideas??? k_thaosta Newbies & FAQs 1 07-18-2002 09:34 AM
